** UPDATE 1/10/2020 SALE PENDING **
1984 Volkswagen Vanagon GL Westfalia Camper Van
$21,000 cash or best offer
4 speed manual transmission
Rear wheel drive
206,XXX Miles
1991 Subaru EJ22 KEP conversion done in 2014
Fridge removed & converted to storage
No AC but it's still there - AC fan works and triggers front radiator fan
No propane tank, stove converted to use small propane bottles
Swivel front seats
No table
Includes removable middle row bench seat
Camper tent canvas in excellent condition, all windows zip open, no leaks, no holes
Garage kept, daily driver
Clean CO title in hand
VIN WV2ZB025XEH090682
Located in Denver, CO
Van sold as is
Contact Dave at ***.**** in area code *** for more info
Photo Gallery https://imgur.com/a/jwgjJs8
We love this van, but are switching to a truck based camper, so we are sadly selling our van. This has been my daily driver & road trip van for the past 5 years. We've been across the country a couple times, and been on countless camping trips with the van.
Van is very reliable, starts every time, keeps up with highway traffic. Happy with the Subaru EJ22 engine. Handles mountain passes reasonably well, I try not to push it too hard when going through the mountains. Likes to cruise around 60/65 MPH. Awesome for camping, diesel furnace for warm nights.
The current list of issues is pretty small, but want to describe them all in detail. There is a knock when turning left and hitting the gas. Recently I had my mechanic look at it, and they said everything looks fine and did not recommend replacing the CV joints. Intermittent coolant overflow tank drips a little bit after parking. I've replaced the tank, but it still drips a little every once in a while. Otherwise, the cooling system works fine, don't have to add coolant, etc... No other leaks. Some seam rust, see photos. Tires will need replacing in the next 10K or so miles. This is my daily driver, these are the issues I was fine driving with.
Jan 2020 Update: Just got the van back from Rocky Mountain Westy. I had them take a look at an idle issue the Van had. Got new plugs, wires, and replaced a bad injector. Engine is running great! Also had a compression test done, engine is strong!
- Cylinder 1 170 psi
- Cylinder 2 165 psi
- Cylinder 3 175 psi
- Cylinder 4 175 psi
Van currently passes emissions testing in Jefferson County, CO.
Purchased in 2014 with around 170,XXX miles on it. The following work was done in 2014 prior to me buying the van
- 1991 Subaru EJ22 KEP conversion (don't know total miles on engine)
- Rebuilt transmission
- New gas tank
- New General Grabber AT tires
- New battery
- New skylight
- New tent canvas
- New topper seals
- Front spindles from 86 Vanagon (I think they will accept bigger brakes)
- New paint / respray
- Reupholstered front seats
- Removed insulation behind cabinets
- Removed fridge & converted to storage
- Removed propane & converted stove to small bottles
- H4 headlights
Since 2014, I have added the following
- Rocky Mountain Westy Twin Peaks rear bumper with hitch
- House battery under driver seat
- Yandina battery combiner (combines house battery to alternator when van is running)
- Blue Sea fuse panel
- Diesel furnace for heating while parked & sleeping, runs on house battery
- JVC KD-X210 digital media receiver (No CD player, aux / usb in only)
- 4 Pioneer TS-D1002R speakers + Dual brand subwoofer under rear bench
- Radio & subwoofer run on house battery with dash power switch
- Dimmable LED light strip above stove & sink, runs on house battery
- Headlight relays
- Starter relay
- Diesel Volkswagen starter + adapter
- Cupholder
- Fire extinguisher
- New Bilstein HD front shocks
- Arduino based LCD gauge outputs the following: Outside temp, speed, rpm, oil pressure, coolant temp, volts
- Smallcar speedometer based VSS
Work Done Since 2014
- New clutch
- New timing belt
- Transmission oil change
- CV joint replaced
- New rear brake shoes and drums
- New oil pan
- New plugs & wires
- Replaced bad injector
- Regular oil & filter changes with Rotella T6 synthetic & Subaru filters
Van comes with
- Tire chains for back wheels
- EvoScan Software + USB cable - Reads Subaru Select Monitor I for engine diagnostics
- Spare Parts
- Bentley repair manual
Spare parts
- Subaru ECU
- Subaru MAF sensor
- Subaru knock sensor
- Subaru alternator belts
- VW coolant overflow tank
- VW ignition switch
Current issues
- Some seam rust, see photos
- Pinstripe from hitting a baby stroller when backing up
- Coolant overflow drips a little bit after running
- Tires likely need replacing within 10K miles
- Knock when turning left and under load, mechanic said does not need work now
- Sink faucet leaks slightly when on
- Cracked dashboard
Edited by driverdave, 21 January 2020 - 05:23 PM.
