Switches in 95’ 8’ CO
#1
Posted 13 January 2020 - 10:00 PM
Thanks
#2
Posted 13 January 2020 - 10:57 PM
There may be a fan mounted so it can blow air past the heat exchanger for the fridge. I've seen them mounted in places where they're hard to find. Maybe the limit switch is in series with the fridge fan switch, so it comes on whenever the top is lowered. Both may need to be "on" for the fan to operate.
Jim
Edited by Jim in Idaho, 13 January 2020 - 10:57 PM.
#3
Posted 14 January 2020 - 05:49 PM
My 99' has a switch next to the thermostat that turns the furnace off. In the ON position the thermostat controls the furnace. In the OFF position the furnace won't turn on.
#4
Posted 14 January 2020 - 08:36 PM
Give the folks at Alaskan a call to see if Brian or any of his shop guys can answer your questions. If you know the ex-owner bought it new, they may have a build sheet for it in their files. Barring that, tracing down where the wires come from and lead to (if possible) may help you out that way. Maybe try that before calling Alaskan?
1988 Ford F-250 HD Lariat 4x4 8 Ft. bed
1976 Alaskan 8 Ft. CO camper
#5
Posted 15 January 2020 - 03:59 AM
