Roof strut install
#1
Posted 23 January 2020 - 05:15 AM
#2
Posted 23 January 2020 - 03:14 PM
Google “site: wanderthewest.com gas strut install” to see a number of threads that will help.
I am haunted by waters
#3
Posted 23 January 2020 - 05:46 PM
In a nutshell its about a 10 minute job.
#4
Posted 23 January 2020 - 07:34 PM
And highly worth while.
2017 Toyota Tacoma with 2000 FWC Eagle
"The nut behind the wheel is the most important one. Don't forget to snug yourself up every once in a while." John D & ri-f
#5
Posted 23 January 2020 - 07:49 PM
thanks!
#6
Posted 23 January 2020 - 08:30 PM
that google search above will give you installation advice will eventually lead you here
http://www.wanderthe...shocks-thingys/
What do you have on your roof? 30# struts are great for empty roofs, #40 are good for small solar panels. I have #80 on mine, and nearly new set of 40# in my garage collecting dust.
#7
Posted 23 January 2020 - 09:09 PM
Howdy
You should install front and rear...the fronts are more helpful than rears.
Good luck with the project......set a day aside to complete it well.....read thru all the discussion.
What screws? Bedding sealant....what weight lifts, how best to secure to camper framing ? etc. etc.
David Graves
#8
Posted 24 January 2020 - 02:42 AM
Great. Thank you. I’ve found the helpful advice of what to purchase, I was hoping to find a more in detail of measuring and to either to screw/bolt/rivet etc. i couldn’t find any of that.
thanks!
I threw bolted both the bottom of both the front and rear mounts then used #10 3/4" hex head bolts for the top mounts.
