Yes it's a different closing angle. My Eagle uses 36" on the inside. But when I mocked them up on the outside the angle is wrong. To span the open amount they are too vertical and won't be able to compress when closing.
I have a question for folks that have converted from inside to outside struts. My Eagle had 60lb inside which were just fine with nothing on the roof. Once I added roof rack and a Glass 160 watt panel it was a very touch lift. I upgraded the inside to 80lb each and it helped a little. I can do it but it's heavy. Space is tight for my big old self inside until the roof goes up. So I've been using a speaker lift as well.
I'm getting ready to buy the struts for the outside to convert. Is there a same weight translation from 2 inside struts to 4 outside? As in I have to 80lb inside. Is that exactly the same as 4 40lb on the outside. On paper both applications are 160lb of lift. Or does the location make a difference? I still haven't accounted for the addition of the Road Shower on the racks yet either. Which will be used occasionally. 5 gallons of water up there.
I'm thinking of going with 4 50lb on the outside and then using my old inside struts as needed when additional weight is on the roof.
Comments and opinions?
Edited by Squatch, 15 February 2018 - 06:56 PM.
