* * * * - 1 votes
ATC Bobcat after one year...
63 replies to this topic
#41 billharr
billharr
  • 2,824 posts
  • LocationStockton CA
Posted 14 October 2014 - 06:02 PM
Your camper and truck are in great shape given the amount of use you have given both of them.  ATC and Toyota do make great products.
Bill
#42 Kodachrome
Kodachrome
  • 369 posts
  • LocationColorado Rockies
Posted 14 October 2014 - 06:40 PM
Bill
I think that is what has served me well though, using the rig enough to develop systems and intervals of maintenance that stay fresh. It's a great platform, fabulous place to live and work from for sure.
My wife took the truck for a spin without the camper on it to get us lunch and to wash it. She came back with a big grin and said it took off like a canon blast without the weight on it, LOL!
Edited by Kodachrome, 14 October 2014 - 06:42 PM.
Instagram
407 HP Supercharged 2005 Tacoma / 550W Solarcharged 2009 ATC Bobcat.
#43 craig333
craig333
    Riley's Human
  • 8,014 posts
  • LocationSacramento
Posted 14 October 2014 - 08:25 PM
I like that diamond plate. I think I'll run by Blue Collar and see if they have any.
#44 Kodachrome
Kodachrome
  • 369 posts
Posted 21 October 2014 - 03:45 PM
Got mine on ebay for $22, I did part of the underside too, mostly to protect the wood since I live in a harsh climate.
But yeah...it looks rather slick in having no wood showing, all industrial like...they even cut it for me.
Edited by Kodachrome, 21 October 2014 - 03:46 PM.
Instagram
#45 craig333
craig333
    Riley's Human
  • 8,014 posts
Posted 22 October 2014 - 03:31 AM
Ebay? Hmmmm, blue collar was much too pricey though I did pick up some cheaper stuff.
#46 craig333
craig333
    Riley's Human
  • 8,014 posts
Posted 01 November 2014 - 04:32 PM
You have the ebay link?
#47 Kodachrome
Kodachrome
  • 369 posts
Posted 23 November 2014 - 04:57 AM
So I am in week three of a month long trip, did two weeks in Death Valley, shot a ton of 4x5 black and white, likely some good stuff in there.....if I can keep my rear in one piece.
The carnage:
I was "Maching at a leisurely pace" as I like to call it down the Racetrack Playa road, about 50MPH on a nice flat section...but there were occasional shadows cast across the road. So I hit a hole pretty hard, an inspection of it days later would reveal it was about 18" deep. Boom.
The suspension greased it, but the truck torqued pretty good. Upon initial inspection, I found my left front camper elevator bolt was broke...shocker. Also bummer because it is the side that you can not easily get to being hidden by the lower pantry cabinets, I am having ATC mod that this week...I need access to *all* those E-bolts at all times, I had a damn spare. So I used the spare E-bolt on the jack bracket with a motorcycle tie down, it's been working great, still on the road.
But then the other damage revealed it self. I blew some oil out of the recently re-built front 2.5" coil over shock. Might need another re-build, might have just blown off excess oil and needs a nitrogen recharge. Now.....here is the doozy. About a week later when finally out of the Racetrack, I am doing about 40MPH up the pre-summit section of Titus Canyon Road, easy-peasy....except the ball joint on my upper A-arm comes out, makes my front wheel cave in and I come to a grinding halt. Thankfully I was in 4WD and it was all very stable. I worked on getting the A-arm put back together for about an hour when fellow colorado folks pulled up and helped, I paid them in ice cream. Once we had another jack under the lower A-arm, it was easy going. What happened here is that the goon who replaced my old ball joints a few years ago had put the snap ring in inside out and upside down. They work by pressure as a safety. If the bearing cup pushes down, then the ring expands even harder. Not the case this time, it popped out...could have been gnarly if at highway speeds on a curve on a 2 lane highway. The failing front wheel bent my sway bar in about 1/2" and ripped my ABS sensor cable apart. I soldered my ABS cable back together, will get the sway bar fixed next week.
This is about the most damage in one shot I have ever had, It's causing me to buy a second tie down and make darn good and sure I can get to all the elevator bolts if I need to...this is the second one I have had broke, it happens, I use the crap out of this truck so it probably will again at some point.
I am camped at Mono Lake, the wind is howling, the camper is cozy and on tight, see you at ATC bright and early Monday morning!
Instagram
#48 pvstoy
pvstoy
  • 2,768 posts
  • LocationCarson City, NV
Posted 23 November 2014 - 05:43 AM
Ouch!  Bad situation but maybe good timing.           Racetrack road... that brings back memories of pulling over and taking the Renuel bumper and winch off the front and putting it in the camper.... :wacko:
Enjoy Mono Lake. let me know if you run into trouble on your way to ATC going through my neck of the woods (sagebrush).
Patrick
2015 FWC Hawk Flatbed
#49 Kodachrome
Kodachrome
  • 369 posts
Posted 25 April 2016 - 01:22 AM
170K miles on truck now, completely re-built super charger, installed completely new headers, exhaust, etc. Also now completely new ECU, exhaust cam gears, all new sensors, 7th fuel injector. Motor was at 236HP stock, now at 407HP. Upgraded coolant system, higher output alternator. New BFG AT/KO-II load range E tires, ready to roll!
  • 1
Instagram
#50 Kodachrome
Kodachrome
  • 369 posts
Posted 23 April 2019 - 10:45 PM
Time for an almost three years to the day update! Mileage is now 194K.
The camper is almost 10 years old now and is just a flat out critical piece of "Camera Equipment" for my work. Since my last post and about two years ago, my wife and I finally got tired of condo living and bought a good sized house about 23 miles away from Aspen where I spent 19 years. Until we bought the house, there was never any way for me to pull the camper off and do underside maintenance to it, kind of a pain. Now it has a dedicated spot outside the garage, a carport cover will go in soon.
All in all, it has been really great to have and use. For example, last year we were evacuated from a wildfire that came within 1/3rd mile of our home and it really helped to load my wife and our cat in short order and live in it for a few days at a friend's ranch nearby. And turn about being fair play, this winter was a really good one, I must have spent 45 days and nights in it while working at the ski areas, often arriving pre-dawn to avoid dangerous conditions and just napping comfortably until the lifts started running.
Everything is working really well but I do need to re-build some things. The vinyl flooring is buckling so I will likely pull the storage box / bench seat assembly and battery box out and re-do it. Another one is that the roof is leaking more now, too many days in a decade of Winter's with snow and ice piling up and being removed. I will probably pull the fans, the solar etc. and try to re-seal it at some point.
But all in all, one of the best investments I have made and I can not imagine living without it.
Edited by Kodachrome, 23 April 2019 - 10:49 PM.
  • 3
Instagram
