FWIW: My furnace does this once in a while, but it only does this when the battery charge is relatively low...like there's not quite enough juice to do the sparking -- and yet there's enough to run the fan (but I can tell from the sound that the fan is running slower than normal).
I have a 05 Granby on a 99 F150 4x4 and have had the same problem on and off for the last 5 years-seems to be related to the battery. Out of habit, if I think I'll use the heater that night to warm up the camper (usually sleep cold-unless it's storming out) , I start the truck and turn on the heater before I call it a night-sort of warm it up. Have had the same problem in the morning-same procedure-turn on the heater and run out and start the truck. Also when I got the camper, I was told to turn off the power and turn it back on again if the heater doesn't work-doesn't work to often. If I leave the thermostat on all night and the battery is good-no problems.
