* * * * - 3 vote(s)
Low Cost Mods
480 replies to this topic
#241 DesertDave
DesertDave
  • 260 posts
  • LocationSan Jose CA
Posted 01 March 2015 - 10:42 PM
On my front dinette Grandby, the nice storage area above the water tank couldn't be accessed without removing both seating cushions.  That rendered it pretty useless until I split the hinge and the storage door to allow it to open with the cushions in place.  Now I can access it while seated at the dinette - which came in handy on the next trip when I needed a little first aid.
Links to my gallery photos
With the lid open
Above tank storage open
with the lid closed
Above tank storage closed
I split the door side of the hinge at two spots with a cutoff wheel on a dremel tool, I split the door at the same two points with a fine tooth hand saw
2014 Grandby FD on a 2007 F350
#242 Happyjax
Happyjax
  • 1,161 posts
  • LocationMaryland
Posted 01 March 2015 - 10:49 PM
Now that's an easy mod which FWC should use:)
2018 Ford F-250. Camper pending :)
#243 Lighthawk
Lighthawk
    Fellow Wanderer
  • 2,755 posts
  • LocationNevada City, CA
Posted 22 March 2015 - 04:17 AM
We returned from our annual DV winter trip determined to replace the stock FWC curtains.  We also had a few ideas about improving the settee.
First stop was the local fabric store; Ben Franklin.  I think they are part of a chain.  We wanderedI the remnants looking for a heavy, upholstery grade fabric to help insulate the single pane, aluminum frame windows that FWC installs in their rigs.  Reminds me of the state of construction standard from thirty years ago, when I installed hundreds of cold aluminum frame windows with single panes.
We lucked out and found 2 1/3 yds of material in earth tones with a pleasing print.  We bought a large spool of poly blend, heavy grade thread.  Total bill was just shy of $22 bucks!  I think we're still running with the $25 budget for Low Cost Mods.   :D
SR got busy with her restored Singer Featherweight I gave her a few years ago.  She reused the guide strip for the OEM curtains with nylon dogs that glide in the aluminum tracks mounted over each fenestration.  They look so much better than the white curtains from FWC, which were cheaper grade fabric and already dirty on our six year old camper.
The big win for us was to design a back support that would pad the front window.  We have a swing around table and will both sit with our backs to the front of the camper.  I've already extended the settee seat top by replacing the OEM seat with an extra piece of 5 ply birch plywood.
http://2015-03-21%2016.31.50-M.jpg
http://2015-03-21%2016.31.40-M.jpg
SR sewed a pocket into the fabric just large enough for a standard 48" x 21" thermarest (extra points for using materials already in your garage  :P )  I used $5 package of screw-attached snap closures.  Oh noes!  I'm now up to $27 bucks!!!  :o
The snaps are mounted in the top of the fabric, allowing quick install of the padded seat back, or removal.  We figure we can open the thermorest valve and deflate the pad to stow it in the gap between the cabinet and the front of the camper.
http://2015-03-21%2016.39.19-M.jpg
http://2015-03-21%2016.32.20-M.jpg
Looking nice and comfy!
Edited by Lighthawk, 22 March 2015 - 04:18 AM.
  • 1
Andy
06 Tundra AC TRD 4x4, 08 Hawk, Ride-Rite bags, Helweg sway bar,18" BFG AT's
Photo galleries at Lighthawkphoto.com
#244 ski3pin
ski3pin
    curmudgeon
  • Site Team
  • 10,541 posts
  • LocationSierra Nevada Range
Posted 22 March 2015 - 04:30 AM
That is a great idea with the thermarest pocket, padding and insulation!
2003 Ford Ranger FX4 Level II 2013 ATC Bobcat SE "And in the end, it's not the years in your life that count. It's the life in your years."- Abraham Lincoln
http://ski3pin.blogspot.com/
#245 GroovyDad
GroovyDad
  • 756 posts
  • LocationReno, NV
Posted 29 March 2015 - 06:20 PM
So, I've been looking at that strip of Velcro that runs along the ceiling for the Arctic Pack and have been pondering its many possibilities.
Here's the first of what will be many more uses for it:
I can simply attach this after I raise the roof and have a paper towel dispenser.  The only problem I can foresee, if it's even a problem at all, would be how this will work when there's condensation on the walls, but I don't think that would a big deal.
I may use that Velcro strip for a hat rack, clothes hooks, utensil holders, etc.
"I only went out for a walk, and finally concluded to stay out till sundown, for going out, I found, was really going in." —John Muir. http://aimlessroamer.blogspot.com/
#246 billharr
billharr
  • 2,521 posts
  • LocationStockton CA
Posted 20 April 2015 - 09:08 PM
On our east coast trip we found we put our shoes on the floor under the over hang on the drivers side cabinet.  Soon we both had two pair of shoes out and the area was getting messy, also they slide around when we traveled. Here is the modification I made to hold our shoes.
Bought two 15" x 15" bicycle cargo nets at REI  $6.95 ea.med_gallery_1903_342_1517669.jpg
Took the metal hooks off and then used zip-ties to join them together making a 15" x 30" net. Installed cup hooks on each end of the over hang area to attach the net. I did put a cup hook in the middle bottom and on top, top center hook has a small bungie attached to it and the net.
You can see the small center bungie in the picture below.
  • 1
#247 billharr
billharr
  • 2,521 posts
Posted 20 April 2015 - 09:13 PM
Had one small damage inside the camper on our east coast trip, the corner to the propane box. One of us hit the bottom of the corner and pulled off the "paper wood grain". Not a big problem but looked bad.  I bought a 3/4" x 1/2" alum angle at HD and cut to fit. Used 4 screws to attach. Looks good and will protect the corner from more damage.
#248 Squatch
Squatch
  • 1,281 posts
  • LocationOn the wrong side of the mountains!
Posted 23 April 2015 - 07:45 PM
I've got a similar issue with the furnace/stove cabinet of the Eagle I just bought. I intend to do the same as you except I'll use clear plastic angle. The kind for protecting sheetrock corners. I have a couple of left over pieces from work on my kids new abode.
#249 100acrehuphalump
100acrehuphalump
  • 540 posts
  • LocationIn a pool of clear crystalline water. Appalachia
Posted 24 April 2015 - 03:43 AM
I'd like to trim each angle of that cabinet in angled brass or copper...
Edited by 100acrehuphalump, 24 April 2015 - 03:44 AM.
2012 F150 XL V8, 4X4, S-Cab, Warn VL 10,000, Bull Bar, E Rated Cooper Discoverer AT/3, Rigid Industries Dually Spots
2015 FWC Hawk
M416 Expedition Trailer
Bayleaf Woof!
#250 100acrehuphalump
100acrehuphalump
  • 540 posts
Posted 29 April 2015 - 12:32 AM
Some low cost additions. A dish rack with lid which fits in my sink from camping world and this folding shower platform made of Poplar. (Liriodendron tulipifera) It's very lightweight and fits under the cabinets in the Hawk. I may try to copy it in Southern Yellow Pine, (Pinus taeda) because pine doesn't rot as quickly as hardwoods do. I was originally thinking about using a hot water heater for a shower pan, but they are so wide and unwieldy-not good for storage. I use only biodegradable shampoo and soaps. Hopefully that's Treading Lightly?...1 of 3
Edited by 100acrehuphalump, 29 April 2015 - 12:39 AM.
2015 FWC Hawk
Bayleaf Woof!
