FWC Camper Weight
60 replies to this topic
#41 Stokeme
Stokeme
  • 373 posts
  • LocationNorCal
Posted 16 December 2017 - 03:47 AM
I am now getting moderately concerned. I just paid to get in the rotation for a Grandby Shell w/extras. I am ordering a 2018 f150 4x4 super-cab 8’ Bed on Monday, HD properly equipped, payload 2700, Gvw 7850. My shell weighs 975? My options add up to 292lbs. ARB fridge 53lbs. That is 1320lbs with no buildout. It will be lighter & leaner but? Table w/lagun mount along with less cabinets than fully loaded. Not too much more heavy stuff. I wanted the 3.5 Ecco boost & not a f250. I may use some for daily driver But I could still order a f250 Monday or beef up the f150 more. All the stuff does add up ... I wish I had a better idea from FWC.
Reading what Camper Rich posted made me think & check ... I will be under his weight, even eventually, but though a f250 is possible, it is not preferred.
#42 iowahiker
iowahiker
  • 487 posts
  • Locationiowa
Posted 16 December 2017 - 01:24 PM
We subtract 100 pounds from FWC shipping weight (not sticker weight) for traveling without the jacks and we subtract 75 pounds for removing the tailgate, more like 50 pounds for your aluminum.  Air bags are frequently added to level the truck when more of the camper weight is on the rear axle.  The extended cab long bed should use the front axle more because of the long wheel base.
#43 jrwdlw
jrwdlw
  • 48 posts
Posted 17 December 2017 - 01:46 AM
I am now getting moderately concerned..... though a f250 is possible, it is not preferred.
Stokeme,
Not to add stress here, but I just sold my 2013 F-150 Super Crew, and bought an F350, crew cab, long bed, 4x4.  My F150 didn't have as much capacity as yours will (1700 lbs), but I just couldn't do what I want.  I had done some weight calcs on what we carry, and with just an 800 lb camper, I would be 500 over.  Make sure you do the math on the axle capacities.  With my F150, I could only put 1470 pounds of the 1700 on the rear axle. Also, the rims would only hold 1678 of the 1700.  When I realized that, I decided it was time to bite the bullet.
The F350 has 3800 lbs of capacity with it's 17" tires and wheels.  If I were to go to 18" (they carry more weight), it would be 4400 lbs.  An F250 crew cab will carry 3230 (long bed) or 3450 (short bed).  If you go with a super cab, it's 3490 and 3560.
Another problem I had was tongue weight,  are you going to tow something?  Leave yourself some capacity for that.  A simple utility trailer will be 250 to 350.  Anything larger, and you may need 500 to 700.
#44 smlobx
smlobx
    Lost again
  • 1,529 posts
  • LocationNorth Carolina
Posted 17 December 2017 - 09:04 PM
It's hard for me to imagine that you will be under your gvwr with a Grandby on a F-150 when you're loaded to go camping.
A friend of mine (on this forum) has his hawk on a F-250 and doesn't feel like he has too much truck.
Just a point of information but the cab of the F-150 and F-250/350 are the same, it's just that the frame and running gear are heavier Duty....Also the engine choices are different.
Edited by smlobx, 17 December 2017 - 09:05 PM.
Eddie
KO4CPL
#45 BillTheHiker
BillTheHiker
  • 307 posts
  • LocationBoise, ID
Posted 20 March 2018 - 10:04 PM
Just weighed my rig at the highway truck scales:
2016 Fleet shell on 2008 Tacoma V6, Access cab, 4x4 TRD off road with two extra progressive leaf springs and E rated tires. Weight includes myself.
Front axle: 2360 lbs
Rear axle: 2760 lbs
Total: 5120 lbs
GVWR on door sticker: 5350
5350 - 5120 = 240 lbs for all gear, food, water. So I figure I will usually be at or maybe a bit below GVWR for most trips.
However, using GAWR gross axle weight rating I will be well under the maximum.
 front: 2755 lbs
 rear:  3110 lbs
 total =  5865
 I previously weighed just the Tacoma at 4330 lbs (including myself), so the camper is 790. I added a counter, sink and two built-in cabinets adding about 30 lbs so subtracting that gives 760 which is very close to the 766 on the manufacturers statement of origin.
#46 ETAV8R
ETAV8R
  • 906 posts
  • LocationRepublik of Kalifornia
Posted 21 March 2018 - 04:10 PM
Remember that your GVWR is for the stock vehicle. Adding better suspension and tires changes things altogether.
  • 1
Founder of D.E.R.P. Desert Exploration & Research Project. A camp proper is a nomads biding place. He may occupy it for a season or only for a single night, according as the site and its surroundings please or do not please the wanderers whim- Horace Kephart.
2009 4x4 Tacoma Access Cab-The Gini
2013 Silver Spur Finch Shell- The Oxcart/Gini's Burden-
http://www.wanderthe...ory/#entry83606
#47 DMWI
DMWI
  • PipPip
  • 20 posts
  • LocationWI
Posted 03 April 2018 - 08:34 PM
Great info on axle bearings.
My Combo:
2006 Tundra Double Cab 4x4 TRD 4.7L
GVW 4965-5010 depending on website.
6600 GVWR
Manual Shows:
3500 lb Front Axle Weight Rating-All Models
3760 lb Rear Axle Weight Rating-Double Cab
(3560 Rear GAWR-Step Side, 3650 Rear GAWR-Standard Bed)
Owner Manual Note:  Individual axle loads should NOT EXCEED Either of the gross axle weight ratings (GAWR)
Total axle loads should not exceed the gross vehicle weight rating. These ratings are given on the vehicle certification label which is located on the door latch post on the left side of the vehicle.
Door Jamb-Vehicle Certification Label states:  The combined weight of occupants and cargo should never exceed 1421 lbs*.
*This label also shows Front and Rear Tire PSI inflation of 32/33psi which were stock tires, not E load rated.
No other labels or tags found in any door jamb or under hood.
*Page 483 of the 2006 Tundra Owner's Manual also lists weight capacity of SR5 4x4 at:  1421lbs with Towing Package, without Moon Roof. This is occupants, accessories and cargo.
2018 Hawk Shell 925lb on sticker in battery cabinet.
Shell options: 2 vents, one with motor 6&8 lbs, roll over sofa 64 lbs, extra battery 53 lbs, Cook Top? and Furnace 25 lbs, Jacks 100 bs.  Option Weights per FWC Website.
Total:  1181 lbs
Shipping Weight:  1125 lbs per FWC Paperwork
CAT Scale: Truck empty with bed mat, 65lbs tools, 230lb driver, rear seat (70lbs?) & tailgate removed (50lbs?), fuel tank full-less 4 gallons:
5320 (3140 Front, 2180 Rear)
CAT Scale:  Truck with new camper, bed mat, 65lbs tools, 230lb driver, rear seat & tailgate removed, fuel tank full, empty propane:
6520 (3180 Front, 3340 Rear)
Scale shows I added: 1200lbs. Less 4 gallons of fuel at 6lbs each = 1176 lbs for camper with 100lb jacks that will stay home. Within 50lbs of FWC Shipping weight.
No water, porta potti, cooler, food, propane, camping gear or moto-gear. Propane Tanks Each 15 lbs empty new before purge, 24lbs Each Full. This will add 350-750.
Estimate Total: 6870-7270lbs.
Empty, stock truck sat tail high:  34" Front, 37" Rear, measured to center of fender wheel wells.
With Camper stock suspension, truck sits level: 34 Front and 34-1/2" Rear, with stock suspension.
Truck is stable, but bump stops hit running on paved back roads. Suspensions Mods will be required, even if under 6600 GVWR which is not likely.
Edited by DMWI, 09 April 2018 - 04:35 PM.
#48 scappoosebrad
scappoosebrad
  • 97 posts
  • LocationScappoose, OR
Posted 05 April 2018 - 08:46 PM
Could you say more?  how does better suspension/tires change the GVWR--better or worse... just trying to educate myself better to this whole weight issue?  Thanks..
#49 JaSAn
JaSAn
    Grumpy Old Man
  • 1,105 posts
  • LocationMinnesota
Posted 06 April 2018 - 12:18 AM
You can add stuff to make your truck handle better, ride better, sit level, etc., but the GVWR does not change.  GVWR and GAWRs were set by the factory and only a licensed (by the NHTSA) upfitter can change it.  They will issue the legal paperwork to change your title and add a sticker to the door post, naming what changes were made, the new GVWR and who made them.  It is expensive and I've only heard of de-rating HDTs for tax purposes.
jim
Renovating Skoldpaddan
2012 Ram 2500 4X4
1951 Dodge Power Wagon
#50 Malamute
Malamute
  • 35 posts
  • LocationRockies
Posted 06 April 2018 - 01:09 AM
 ^^^ Thank you.
 Theres more to the rating than tires and springs. Brakes, drive line components, and many other things are tied up in the rating, as well as the axle bearings which were part of this discussion.
