Back-up Camera Thread
77 replies to this topic
#71 solinski
solinski
    Newbie
  • Pip
  • 8 posts
  • Locationredding,ca.
Posted 29 October 2016 - 06:01 PM
My 2004 Six Pac T100 S hard-side has a low mounted window in the camper entry door. I can see directly behind me with my trucks rear view mirror, so no camera needed. I wonder why the camper mfg. stopped installing these very handy low mount windows? I will have to address this issue with my soon to own ATC Bobcat. Maybe I can get Marty to install a low mount window in the door?
Solinski
#72 craig333
craig333
    Riley's Human
  • 6,269 posts
  • LocationSacramento
Posted 26 December 2016 - 05:54 PM
Just got a pyle 7200 for Christmas. Hard wired. The dent in my bumper is proof enough I need one. Towing the Jeep occasionally I think I want to mount it up high (if there's enough cable) but is there a downside to mounting it up high besides having to disconnect when the camper comes off? If there's enough cable I think I'll get some two sided tape and try some different locations before permanently mounting the camera.
Craig KK6AUI _________________________ 2004 2500 CTD 4X4 FWC HAWK 1960 CJ5
#73 PaulT
PaulT
    Need gumbo
  • 1,753 posts
  • LocationHillsboro, Oregon
Posted 26 December 2016 - 08:27 PM
The primary disadvantage I see is the need to put some kind of cap on both the camper side of the harness and the truck side of the harness when removing the camper. This is so that neither connector gets filled with dust, mud, or corrosion that could keep the units from either being plugged together or getting the contacts fouled so badly that electrical contact is impaired when the camper goes back on the truck.
My Tundra came with such caps in the glove box with dire warning to use them when removing the tailgate.
.ps. Place some objects behind your truck in strategic places to mark the corners of the viewing area with the original set up.  That way when you try new locations for mounting the camera, you can verify you are getting a reasonably similar result. Might shorten the error part of trial and error.
Edited by PaulT, 26 December 2016 - 08:31 PM.
#74 craig333
craig333
    Riley's Human
  • 6,269 posts
Posted 26 December 2016 - 11:00 PM
Turned out I barely had enough cable to use the traditional above the license plate mounting spot so that'll just have to do.
#75 SCUD
SCUD
  • 71 posts
  • LocationOregon City, Oregon
Posted 08 May 2017 - 01:17 AM
My Garmin DriveSmart 50 navigator works with the Garmin BC 30 wireless back-up camera.  The camera is mounted inside the camper between the upper part of the rear door window and the screen.  There's very little road spray deposit in that position and it's all nice & dry, which is a consideration here in Orygun.  It's powered by a cigarette lighter plug in the camper.  Like some others the always on option works best for me.
2016 4WC Fleet FD, with most options and 160W Zamp roof panel (1450# dry)
2018 GMC Sierra 2500 SLT Z71 6.0 liter Crew Cab 4WD, 6'-6" bed (replaces 2008 Canyon)
Goodyear Wrangler SR-A LT265/60R20 121/118SE
TorkLift StableLoads, no air bags
#76 birdiebryce
birdiebryce
    Newbie
  • Pip
  • 1 posts
Posted 17 May 2017 - 07:05 PM
Hey SCUD, im looking to do the same set up as you with the Garmin. When you plud directly into the 12V lighter in the camper, did you also need to go into the brake power at all? Is the cord long enough to reach the 12V plug in?
When it's plugged into the 12V does that run the camera full, meaning you can see behind at all times? Is there anything special I need to do when plugging in?
Thanks for the help.
Bryce.
#77 JeffWright
JeffWright
  • PipPip
  • 18 posts
Posted 30 May 2017 - 03:41 PM
FYI: I bought this one on Amazon:
Backup Camera and Monitor Kit For Car,Universal Waterproof Rear-view License Plate Car Rear Backup Camera + 4.3 LCD Rear View Monitor https://www.amazon.c...p_5MKybj4fY7ACg
It's not horrible but I wouldn't buy it again. The camera is not wide enough to get an effective view. All it's really good for is just double checking if there is something behind you. It's not really going to help you actually park. It was also pretty cloudy everywhere but the middle of the image from day 1.
I'll probably buy another camera and use the existing monitor and wiring. I think if I get a different camera I'll be in good shape
#78 Idahostat
Idahostat
  • 45 posts
  • LocationBoise, Idaho
Posted 12 July 2017 - 10:36 PM
Hello
Has anyone used this site? They offer a variety of wired, wireless cameras for "RV" applications. tadibrothers.com
I read a interview over on truckcampermagzine.com of a alaskan camper owner who was using a split screen and multiple cameras to monitor is perimeter and his LCD split screen and "ice cube" cameras looks somewhat like what those guys sell.
Terence
Terence
Ford F350XL, ( Badging indicates "STX" ) CC-LB-SRW, FX4, Snow plow/Camper prep. Bought ( August 2017, used Hallmark Everest ( Mfg in Dec 2015 ).
