Anyone tried the Torklift Derringer Fast Guns on their 4WC?
turnbuckles Derringer Torklift
12 replies to this topic
#1 Bajaahh
Bajaahh
  • 53 posts
  • LocationEncinitas CA, (San Diego County)
Posted 21 January 2014 - 05:35 AM
I ended up buying the Torklift Derringer Fast Guns to replace the turnbuckles on my Finch. Im hoping there is enough room to make this possible. I might have to turn the eye bolts (that are on the camper) to get the right angle for the guns to work. I was hoping that someone has done this and can give any advice based on their experience.
Thanks in advance.
2008 4x4 Tacoma with RideRite airbags/Tundra Bilsteins. 2009 4WC Finch
#2 Argonaut20
Argonaut20
  • 432 posts
Posted 21 January 2014 - 02:51 PM
There wasn't room enough in the bed to use the derringers for tie down in the bed. Moving the eye bolt might work, but the eye bolt in the bed and the eye bolt on the camper have to be further apart than they are on my rig. I do use the derringers in front on the Tork Lift mounts and I may put Tork Lift on the back because they make it sooo easy to lash the camper down.
 2006 Tacoma, '66 AS Caravel,  2002 Eagle
#3 chnlisle
chnlisle
    Post Master
  • 3,811 posts
  • LocationThe Old Pueblo
Posted 21 January 2014 - 05:41 PM
I like them
JayAronowSales.com
(520)579-9610
jayaronow@gmail.com
#4 Bajaahh
Bajaahh
  • 53 posts
Posted 22 January 2014 - 03:44 AM
OK thanks. Im gonna give it a go soon but I was trying to get some input for what to expect
#5 Bwht4x4
Bwht4x4
  • 427 posts
  • LocationMorro Bay
Posted 22 January 2014 - 04:24 AM
Please let me know how these work.  I'd like to pull the trigger on them.
2018 Dodge Ram 2500 Quad Cab, 4WD, CTD paired with a 2013 FWC Hawk
#6 JimW
JimW
  • PipPip
  • 14 posts
  • LocationCentral Valley, California
Posted 22 January 2014 - 04:47 AM
I can't comment on a Finch, but on my Hawk shell I had to add a "J" bolt to the Derringers for the back. I had to set the angle to catch the eye bolt just right and there is an up and down side I need to watch out for. In the front I use the turnbuckles and make small adjustments each time but the Derringer is what tightens up to make the connection. I can do all 4 corners in about 5 minutes ( with no cursing or contorting). I put the camper on and take it off after trips quite often.
#7 esimmers
esimmers
  • 170 posts
Posted 22 January 2014 - 04:58 AM
Here's a tip for fast on and off with the turnbuckles. Get a felt marker and label each turnbuckle with which camper corner it's to be used since the needed length will vary from corner to corner. Next mark a "T" for tighten and an arrow on each turnbuckle so you'll always know which way to turn. Use a stubby screwdriver or something similar to either tighten or loosen that half turn that's the hardest. After a couple of practices, you'll have turnbuckle installation or removal time down to one minute each. No kidding.
#8 slimboy51
slimboy51
  • PipPip
  • 18 posts
  • Locationyuma,az
Posted 20 February 2014 - 04:32 PM
I recently installed the derringer torklift on my Hawk in a 3/4 ton Dodge . They work great , I would recommend them .
#9 Bajaahh
Bajaahh
  • 53 posts
Posted 25 February 2014 - 05:00 PM
Well, they didn't work on my Finch.
There wasn't enough room to pull the handle down. Im bummed, so Im back to the shoulder dislocating yoga contortionist turnbuckles...
Anyway, I think they will work for someone that has a full size truck and camper.
I'll let them go for $80 plus shipping...
E-mail me at Bajaahh@hotmail.com
#10 Bwht4x4
Bwht4x4
  • 427 posts
  • LocationMorro Bay
Posted 25 February 2014 - 05:02 PM
Damn, I pick mine up today and they cost me $125.  Maybe they won't work  ;) and I'll get back to you.  Hopefully someone buys them from you though.
I have a full size truck with a Hawk so I hope they fit.
Also tagged with one or more of these keywords: turnbuckles, Derringer, Torklift
