Anyone tried the Torklift Derringer Fast Guns on their 4WC?
turnbuckles Derringer Torklift
12 replies to this topic
#11 fish more
fish more
  • 795 posts
  • LocationSierra Foothills
Posted 03 March 2014 - 01:15 AM
I have been using the Fast Guns for some time now. I added j bolts and two quick links to each one. Once set up, mark each one for the position, r/f,l/f, r/r and l/r. You will have to adjust when reinstalling your camper if you get the camper off center. They are mush better than dealing with turnbuckles. The one I use on the left front is upside down to fit in that area. The quick links make it easier to hook up to the eye bolts, once locked into place the quick links and fast guns become one unit, and they will not come loose. One word  of caution, the leverage of the fast guns can over tighten and cause stress to the floor of your truck, causing cracks if you are not careful.
#12 Bwht4x4
Bwht4x4
  • 427 posts
  • LocationMorro Bay
Posted 04 March 2014 - 05:22 AM
I picked some up and tried to get them to work yesterday.  It is possible to get them to work, but the length of the j-hook has to be perfect and isn't easily adjusted.  As fish more stated they are extremely powerful binders and could do some damage.  I decided against them as I figured out a much better plan with some stronger turnbuckles that should save time on the install each time.
2018 Dodge Ram 2500 Quad Cab, 4WD, CTD paired with a 2013 FWC Hawk
#13 overtheborder
overtheborder
  • PipPip
  • 29 posts
  • LocationNorth Idaho and Southern BC
Posted 30 August 2016 - 02:51 AM
So what is your approach that saves install time? Did it pan out the way you had hoped?
Also tagged with one or more of these keywords: turnbuckles, Derringer, Torklift
