I don't totally agree with this repair method. The wire FWC uses has thick strands and a semi rigid outer covering. This type of wire is meant for a stationary environment such as your house not a folding roof panel. Just splicing the existing wire is only a temporary fix.
When my wiring failed I cut out the section behind the roof panels and replaced it with a pliable wire. So far it's working well.
Reading this and the other 2 threads, I'd like to get some of that pliable/flexible wire. Anybody have suggestions on what to get or what I should search for? Can you get it at Home Depot or the local hardware store?
Thank you
