Ultimate Flexible Solar Panels - successes and warranty replacements
85 replies to this topic
#81 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,962 posts
  • LocationCalgary, Alberta
Posted 20 June 2021 - 04:44 AM
I don’t have 80# shocks, but, I have to ask Vic, that roof is a load. What ... do you eat for breakfast? :) Dead lift?! Do the (steroidal) 80# lifter shocks add that much assistance comparatively?
I'm nowhere near as strong as I used to be.  Near death experience 3 years ago took a lot out of me.  No weights since that time.  Technique is a big part of it, as I use my legs (and head) instead of my arms.  The 80# lifters mean that once I get the roof 25% of the way up I can shift position (switch to arms) and it won't come back down on its own.
The thing about glass/residential/commercial panel is that the innovation/market is huge, and in a year or two the same size/weight panel will be putting out 2x the power.  I'm waiting for the latest 600+W panels to be available to consumers, and will jump on that as my next upgrade.
#82 Will.I.Am
Will.I.Am
  • 34 posts
  • LocationSanta Cruz, California
Posted 26 July 2023 - 05:03 AM
Update on this 2021 install.  One of the Renogy 175W panels has failed.  Some kind of delamination problem, just like my ancient surfboards.  The other Renogy 175 panel is still looking and performing well.
IMG 2397
I hadn't thought of using a single high wattage residential panel Vic...well, maybe next time when these flexible panels die in a few years!
Instead, I bought a couple Renogy 175W panels and used aluminum Z bars (similar to what cent323 mentioned) to create (re-create I guess) a more rigid panel, then mounted to the yak tracks.  It's a solid install, and each panel with the aluminum frame weights in at 11lbs...so 22lbs total for the two panels, and 350W total.
2005 FWC Hawk occasionally riding atop a 2000 Silverado LS 4wd w/Toyo A/T's, Supersprings.
Gramming on the Instagram.
#83 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,962 posts
Posted 27 July 2023 - 02:18 AM
And to follow up on that, my 330W glass panel is still working fine.
#84 Will.I.Am
Will.I.Am
  • 34 posts
Posted 27 July 2023 - 03:54 AM
Haha...yep I figured as much Vic. I'm thinking about this beast as a replacement: https://www.amazon.c...4NAV5T95KM&th=1
#85 Will.I.Am
Will.I.Am
  • 34 posts
Posted 27 July 2023 - 03:57 AM
One thing I do think about though as an advantage of having 2 panels is the series bump in higher voltage and low amps which lets me get away with the stock wiring in my 2005 4 wheel camper.
#86 buckland
buckland
  • 3,079 posts
  • LocationNew England
Posted 27 July 2023 - 11:49 AM
I have a 200 Watt Renogy (glass) 0n the roof and a 100 Watt Renogy Flex that I use with a 15 ft cord and position on the windshield with wipers up to sit on for air space. Also shades the interior. It is mostly stored away until needed so little wear and tear. It has been great now for 6 years so far.
  • 1
Lordwoodcraft  instagram        Rob
The only people who ever get anyplace interesting are the people who get lost.
Henry David Thoreau
"Work to achieve not to acquire"
