Bigfoot, are you planning to convert to a frame-mounted tiedown (the Torklift, I assume) because of bad experieces you've had with the box-mounted Happijac, or simply that you anticipate wanting the extra strength and peace of mind somewhere down the road?
I ask because one option we're still considering is to get AnchorGuard turnbuckles for our front Happijac box-mounted front system, and add frame-mounted Torklift tiedowns and Spring Load XLs or Fastguns for the rear. We could do the rest of the repair in a second stage if we still have concerns, in the mean time I think we can refrain from doing anything too crazy and see what happens.
The Happijac front tiedowns have worked okay but I don't like the very short distance for the turnbuckle and the need for a special mounting plate on the camper (to increase the distance). It just doesn't look like a clean installation to me. Also, from what I have read the frame mounts put less stress on the pickup box although I don't know if that is significant. My only reason for going with the Happijac originally was better clearance but now that I have driven the rig on bad roads I do not think that is a problem.
