That looks great. Nice job!!!
I don't think your model is wired with a converter, so shore power may have some different options.
Major decision is whether to power the fridge directly from 110 volt or to have the 110 volt charge the battery while it is running the fridge.
One option is to wire in a converter than wire the converter to your fuse panel (110 power converted to 12 volt to run your system)
Or put in a battery charger that is powered by 110 volt that just charges your batteries directly (110 power to battery charger that converts it to 12 volt to charge the batteries).
Another options would be to wire a 110 outlet to your fridge that runs whenever you are plugged in.
I would think the easiest answer is to plug in a battery charger from a 110 oultet that just charges your batteries.
Maybe someone who has done this mod or FWC could give us some better direction here.
Edited by DrJ, 03 November 2015 - 05:46 AM.
