Enjoy the "new truck/camper".
Glad things worked out and you didn't have much stress.
Posted 27 February 2016 - 01:13 AM
Posted 01 March 2016 - 05:29 AM
So I picked up the truck and camper this weekend. The truck seemed like the day i bought it. The stiff Deaver suspension was a great match once the camper was on. FWC put on the camper. The door was replaced, the trimlines around the roof were replaced. The scratches were minor. First thing on my list now is to get different turnbuckles. I definitely dont want to rely on the stock turnbuckles ever again.
Thank you all for the advise and concern. I hope to take her out camping this weekend. Looking forward to enjoying my toys more now that I brought them back from the dead.
Posted 01 March 2016 - 05:50 AM
2015 Silverado Crew Cab Duramax and 2015 Front Dinette Grandby
One can change the world, it only requires kindness
http://www.truckcamp...g-family-earth/
Posted 01 March 2016 - 12:46 PM
I have safety chains at all four corners and the stock FWC turnbuckles. $10 of chain cut to fit with bolt cutters and $35 of quick links.
Posted 01 March 2016 - 02:00 PM
I don't recommend stainless turnbuckles because of the metal's low strength and relatively high elasticity (meaning that they stretch easily and at low load).
1500, even 2000 lbs tensile WLL sounds like a lot until you factor in any angle that might be involved with the direction of the actual loading. A simple way to see this is to consider a 3-4-5 triangle. If the turnbuckle is aligned with the '3' side and the resultant angle of the pull happens to align with the '5' side then what ever the strain is can be multiplied by 5/3. That takes a 1200 lbs loading and makes it a 2000 lbs load to the turnbuckle. Make the direction of the loading an even greater angle and the loading on the turnbuckle increases accordingly.
Jaw - Jaw is a good plan, but I'd suggest going with a higher load WLL (say 3000lbs. +) which will likely put you into a galvanized turnbuckle. Given what you're bolting to there's no gain in going with extreme over-kill, just don't under rate the job that you're assigning to the turnbuckle.
Posted 01 March 2016 - 02:52 PM
srileo, congrats on getting this behind you, you deserve some fun time now using your rig. Have fun and travel safe!
2003 Ford Ranger FX4 Level II 2013 ATC Bobcat SE "And in the end, it's not the years in your life that count. It's the life in your years."- Abraham Lincoln http://ski3pin.blogspot.com/
Posted 03 March 2016 - 01:59 AM
Glad this chapter is closed. Heres to a new chapter this weekend!
2016 Ford F150 SuperCab 4X4 Lariat 2.7 EcoBoost Engine
2016 FWC Hawk Front Dinette Silver Spur
