INDEED!... my box arrived intact as did the panel. Looks great....$115 for 160W still don't know how they can do it but if this works I will be cooking. I have Yakima tracks and have the 4 slide in flat nuts... just need to buy same thread bolts and lock washers. Speaking of which... how does one tighten up the bolts under there? will be a squeeze. I see you removed the MC4 connectors. I have a set of M & F cord plugs from FWC... I haven't bought the wire to go through the camper from where the roof wire comes out (in the Eagle 2011) under the cabinet where the water tank access is. I wall mounted a plug 4 years ago and ran the wires across the water tank area to my batteries (under couch). I forgot what wire size to use. The roof access box down to the water tank is hard wired so will use same size I suppose. Any advice on wiring the plug at panel...length of cord? ETC.
I currently have a portable 90 watt (on a tripod stand) I will remove the 6L and replace with the 20L. Sunsaver (morningstar). I am building a rustic cabin in the woods and will use that panel there with the 6L.
I can't imagine needing more the 160 watts ... I got by fine on the 90 (we have a Ingle fridge and LED lights)
Thanks for the photos and Fluke #'s....i use one too. (nice pile of cord wood)
