Help with post of pictures
#1
Posted 01 January 2017 - 06:48 AM
I received a few photos of our camper, under construction at ATC from a fellow member. I would like to share them, but have been unable to due to size. Can anyone help to resize and post them?
Thanks Russ
#2
Posted 01 January 2017 - 08:12 AM
http://www.wanderthe...ts-and-gallery/
I am haunted by waters
#3
Posted 01 January 2017 - 03:26 PM
Will give it a try. Happy New Year.
Russ
#4
Posted 01 January 2017 - 04:30 PM
I responded to your post that was displaying links not images.
You want to paste the image URL directly into the image icon that is at the top menu while creating a post.
If you use the More Reply Options button at bottom, right corner, you will be able to see if your post has the images showing.
For photobucket it seems the best choice is the Direct share, which copies the web address of the image.
2021 RAM 3500 Crew 4x4, 6.4 hemi/8 speed trans with 4.10 gears, Timber Grove bags, Falken Wildpeak 35" tires.
OEV Aluma 6.75 flatbed, Bundutec Odyssey camper on order for 2024
For this year we're still using our 2008 FWC Hawk with victron DC-DC charger, 130w solar, MPPT controler
with 2000w inverter and external 120v output and 12v solar input with 100w portable solar. http://lighthawkphoto.com
#5
Posted 01 January 2017 - 05:04 PM
#6
Posted 01 January 2017 - 05:38 PM
I always copy and paste the IMG info. Unfortunately photobucket continues to go downhill. I'll probably switch sites soon.
#7
Posted 03 January 2017 - 01:31 AM
IF you are a Mac owner....to resize there are a few options and you can try them if you like with a PC if this what you have. Simply drag photo to an email... select size (top right corner) small medium large.... email it to yourself ... when it comes in drag photo to the desk top... it is now resized.... OR
open the photo in "Preview" ...go to file> export> choose jpg> use the slide dial to change the size.
One can do this multiple times... and there are other short cuts....
Edited by buckland, 03 January 2017 - 01:32 AM.
2016 Duramax 2.8 Diesel long bed Colorado 4WD with 2011 Eagle
#8
Posted 03 January 2017 - 08:53 AM
