Fellow Wanders,
As this forum confirms, there appears to be the challenge of finding that ‘perfect’ tool for the job, in this case a bike rack that works with our campers.
Firstly, let me preface this by saying, I’ve done 15,000+ of miles traveling with bikes on the back of my vehicles, many of them off-road and I’ve tried a few versions of bike carriers. I currently have and used: Thule T2 (hitch), Thule Parkway (hitch), Thule Big Mouths (roof), Thule Pelotons (roof), Thule Low Rider (fork mount), Yakima Holdup (Hitch) and various others.
Each has its advantages, uses and applications. For example, if you have a carbon frame (or a metal you don’t want to scratch), then the T2 or Holdup are superior as they don’t touch the fame. However, what I discovered is that sometimes the best answer is a combination of several top products.
I have an ‘08 Tundra with Hawk and soon to have an Aluminess rear bumper system. With the swing arms of the Aluminess, I needed something to clear those swing arms and I don’t want to struggle with the bikes and yet be able get in and out easily with them being secure for off-roading and against theft.
I will send some picts, but here’s what I have assembled:
- I used a “Wilco Hitch Swing” to provide the swing out component.
- I took my Yakima Hold up and cut the brackets off the factory hitch mount and ‘swing-up’ arm and welded them onto a Thule T2 Extension (This has an non-standard inner sleeve size, so I got it from e-trailer). This now serves two purposes: 1) it works for adding two more bikes when I use my Thule T2, AND 2) I now have a 2 bike holder on a straight bar.
- Note, the T2 extension has welded in captive nuts (metric) so there is no shaking or unnecessary movement.
- To attach the T2 Extension to the Wilco Swing Hitch, I cut a standard 2” square steel tube to the length needed to clear my Aluminess boxes. The T2 Extension now works with standard 2” square tube which works perfect with the hitch (actually I have two, one short one ~6” for when I’m just using the swing hitch and the long one to clear the bumper boxes).
- Building upon, Yakima’s and Thule’s experience, I have welded in captive nuts so that it bolts into the hitch. The bolts are long and I have drilled them so that when they ‘poke out’ the other side, so that a safety pin can be installed.
- With the Hitch swing locked onto the truck and bikes bolted onto the swing, I then add a lock cable from the bike to the swing arm (there’s a lock point built in, see pict).
The result is a rock solid offroad bike rack that can be custom fit to your camper / bumper config that protects your bike from scratches, keeps it in the slipstream of your truck, keeps it secure, and swings out for easy access to your entry portal.
Downside: This is / was not cheap and you need to do some welding, drilling & fabrication.
https://www.4wd.com/...XxoCdjwQAvD_BwE
https://www.rei.com/...NBoCyj0QAvD_BwE
