1/4 inch thick, 3" wide
#51
Posted 27 March 2019 - 01:56 PM
2016 F150, FX4, XLT super cab
2019 FWC Hawk Shell
2009 Ford Ranger 4x4, XLT, Supercab total loss on 7/30/19
2014 FWC Shell total loss on 7/30/19
#52
Posted 27 March 2019 - 05:21 PM
Thank You!
Rob
#54
Posted 27 June 2020 - 01:01 AM
Alu-Cab replacement for factory installed Eezi-Awn. I think the incorporation of the corner jack bracket is significant and I plan to do something similar for my Shadow Awn.
https://expeditionpo...batwing.196140/
- 2016 Power Wagon - King/Thuren/Carli/Air Lift/Daystar suspension
- 2017 FWC Hawk
#55
Posted 28 June 2020 - 03:57 AM
Hi
What are you using to anchor the end of your Batwing awning? Do you use the jack mounts at the left rear side? Thanks in advance. i have a Hawk with the Batwing that i have not set up yet.
kag
I originally mounted the awning with jack bracket mounts I fabricated. They were 1x2 aluminum uprights with 1 1/4" (1/4" thick) angle for the top. The rear upright was solid bar and the front 1/4 " hollow tube. They did require mounting high enough to clear the door when deployed and out enough to clear the lowered roof.
They worked great but I decided to change them because I didn't like having to remove them to reinstall the jacks over the winter. I ended up replacing them with bolt on wall mounts, made from the same 1 1/4" aluminum angle (1/4" thick) with the wall mount being 2x3" 1/4" angle aluminum. I bought materials for three mounts but only ended up using two mounts.
~Jim2000 Tundra AC- 2000 FWC Ranger
2017 Tundra DC - 2017 ATC Panther
#56
Posted 27 July 2021 - 08:52 PM
Thank You!
Rob
Rob,
Did you end up getting it installed? how'd it go? Did you simply bolt through the camper or find the aluminum frame?
- Marco
2010 Tundra DC w/ 2021 FWC Hawk, 1997 Toyota Landcruiser, 1982 Toyota Landcruiser
#57
Posted 27 July 2021 - 09:16 PM
Life lately is happening while I make other plans... this last year all is like watching a 5 year old have a tantrum.
I have made no headway on the awning but find it hopeful that FWC now installs the Alu-cab awning... I'd follow their guidelines.
Maybe next year for me.
#58
Posted 27 July 2021 - 09:38 PM
no problem, thanks for the reply!
- Marco
#59
Posted 27 July 2021 - 11:51 PM
no problem, thanks for the reply!or
mule outfitters makes custom brkts to mount the alu cab awning. i purchased thru local fwc dealer here in pdx, and had them do the install on my atc.the brkts work, and the awning is excellent.
when i was specing my atc i initially asked for jack brkts that went all the to top of camper on passenger side. i changed that to std before build, but in retrospect i think having jack brkt go all the way to the top, would give more awning mounting options.
Oregon
#60
Posted 28 July 2021 - 01:25 AM
I orginally bought the Mule brackets which were very nicely made but did not hold up the extra weight of my Batwing. So I welded up some steel jack bracket holders. They are bombproof although a little heavy (16lbs each). I probably will just end up bolting right to the camper at some point. I LOVE the Batwing and this system does work great though!
