1983 FWC Blazer Model on a First Gen Blazer
blazer
15 replies to this topic
#11 Blazer_FWC
Blazer_FWC
    Newbie
  • Pip
  • 5 posts
Posted 26 March 2017 - 12:27 AM
According to what I have read - the camper is roughly the same as the standard fiberglass top that came on these Blazers from the factory - so about 250-300 lbs. is the weight range.
#12 longhorn1
longhorn1
    Ouch, that stings!
  • 2,812 posts
  • LocationCarmel, Indiana
Posted 26 March 2017 - 06:07 PM
Nice. Look forward to pictures during you upgrades. jd
http://texaslonghorns01.blogspot.com/
Ford F-250 Long bed, 2014 Grandby
#13 Old Iron
Old Iron
  • PipPip
  • 18 posts
  • LocationSanta Ana, CA
Posted 17 May 2017 - 12:38 AM
I have a 1984 Blazer FWC on my 1972 K5 Blazer. The posted weight is 700lbs with propane and water tanks full. Yours looks to have lead a rougher life than mine, but nothing that couldn't be fixed. The biggest problem with these era campers is that they used particle board on the exposed front surface of the camper right behind the Blazer door windows. Yours has seen moisture and has deteriorated a bit. I sealed mine by covering it with a sheet of textured white vinyl that can be found at Home Depot. The biggest ticket item to fix/replace on the camper is the pop-up vinyl. Hopefully yours is free of holes or tears, and free of mold within the interior thermal insulation. You will really enjoy using it once you get it sorted out.
Edited by Old Iron, 17 May 2017 - 12:39 AM.
  • 2
#14 DavidGraves
DavidGraves
  • 1,205 posts
Posted 17 May 2017 - 05:29 AM
A bit off topic....my brother bought new a 77 Blazer with the Chalet integrated camper....a fiberglass rendering with a pop up top....they were available  from GM but I am unsure who really made them.
Were the FMC campers sold new or installed aftermarket for Blazer owners ?
David Graves
#15 LuckyDan
LuckyDan
  • 634 posts
  • LocationBased in Eastern, NOW CENTRAL Oregon
Posted 17 May 2017 - 06:04 AM
They "Chalets" were built for GM by Chinook RV. A little bit about them here:
https://www.tincanto...trade_magazines
Scroll down in the article. The Chalet stuff is in a way.
Old, bum around in Ford and an even older FWC Grandby
New Mantra: "Everyday camping is just making up for lost time"
#16 Old Iron
Old Iron
  • PipPip
  • 18 posts
Posted 17 May 2017 - 05:44 PM
The FWC Blazer models were sold new from FWC, without a Blazer attached:). No connection to GM. I'm not sure who was responsible for bobbing a 69-72 Blazer full hardtop to form the front cab cover. Perhaps FWC had a template that was used to mark the cut line, and they did it in their factory using the new owners hardtop, or maybe they left it up to the new owner. All I know is that I had to bob a donor hardtop myself, without a template when I found my camper. Measured hundreds of times and cut once!
Also tagged with one or more of these keywords: blazer
