RafterC
What are the three lowest grades in school?
Posted 29 January 2018 - 05:05 AM
RafterC
2016 Ford F150 SuperCab 4X4 Lariat 2.7 EcoBoost Engine
2016 FWC Hawk Front Dinette Silver Spur
Posted 29 January 2018 - 04:52 PM
Has anyone ever heard of FWC jack brackets failing under any condition?
Does fluid in a gas container provide a dampening effect on wash board road as opposed to a solid weight? Engineers?
I'm just a redneck fabricator, LOL.
Howdy
I would think that a partially full jerry can or other fuel container would be much worse than the equivalent solid weight.
I know many liquid bulk tank truck drivers.
Even with the bulkhead and baffels designed inside these tanks my friends
describe a whole different driving experience caused by the "slosh factor" as the liquid load shifts.
David Graves
Posted 29 January 2018 - 06:19 PM
Posted 30 January 2018 - 01:27 PM
My concern stems from the potential results of a mount failure. Not just the obvious possibility for fire, but also what such a failure could/would do the to the jack bracket's attachment to the camper.
Two bolts thru the jack bracket and one or two bolts somewhere else would be a LOT more robust solution than just a couple bolts thru the jack bracket.
Posted 30 January 2018 - 05:55 PM
Good to add more support points but determining the "somewhere else" keeps me from jigging up a fuel bracket...
Phil
Posted 30 January 2018 - 09:49 PM
Cayuse and me en route to Tuweep...with our AT mounted gas cans.
The full 5 gal. is a little difficult for me to get down and back up, but not too bad. I have to stand on my camper steps.
Was full time with it on there for 5 months and camped pretty much every weekend with a ton of off-road and washboard etc. and it's been solid.
https://no-destination.org/ .:. https://razorgirls.org/
2014 Tacoma DCLB + 2015 FWC Fleet
Posted 31 January 2018 - 02:21 AM
Phil
Yeah, that IS the $64 question, isn't it? Looks like Craig has one good solution.
Posted 01 February 2018 - 12:53 AM
I purchased a Hitchgate with dual fuel can holders (and a Hi-lift holder as well) i have two Scepter MFC's (and also a Scepter MWC water can if water is required instead of 2 x extra fuel).
I've carried the Sceptor MFC's on my old Xterra all over, up and down elevation gains like Engineer Pass, in extreme summer temperatures, and they've never complained at all. They do swell in the heat, but man they are strong tough fuel cans. i could probably drive over one without much issue. I do have their lid spanner, which i highly recommend, and their clear long nozzle, which makes refueling a breeze. The MFC's have a built in vent through the handle, so they re-fill extremely quickly. And they're made in Canada...so I figure bonus point for that.
Edited by trikebubble, 01 February 2018 - 12:54 AM.
Posted 01 February 2018 - 02:34 AM
Craig knows his stuff and is thoughtful...my problem is drilling into the Hawk to attach anything and while not knowing where the strength members in the frame are located...bolting or screwing into wood or plastic to anchor or support scares me; especially when bouncing and jarring off road...I am toying with the idea of a vertical brace to the bumper...still need to really think this through first and validate, just for me, if I need more than 26 gallons of fuel on-board..cost vs benefit in terms of weight, weight location and structural integrity off road..
Do appreciate all the ideas offered!
Thanks everyone.
Phil
