* * * - - 1 votes
Water tank 'fill' meter - what does it measure?
18 replies to this topic
#11 Wallowa
Wallowa
    Double Ought
  • 2,173 posts
  • LocationNE Oregon
Posted 01 October 2017 - 03:32 PM
Another view...off road beyond most supplies we are concerned with the LCDs; what will we run out of first that we need.
Just considering the Hawk:  Electricity, water, propane.  We carry extra water, battery lights, down sleeping bags and a backup camping stove so even if our two batteries can't reach a sufficient charge [solar or truck alternator] to power the water pump or start the furnace we can stretch our stay or egress time.
What puzzles me is to go off road with less that the 26 gallons of water that is possible in our Hawk.  Water is the limiter not weight of the water.  If the weight of the water is more than the truck/FWC combo can handle then the combo needs to be re-evaluated. The "dummy lights" in the Hawk serve us well and we can estimate when it is time to search for a water source be that a stream, lake or municipal water system.  Yes, we carry a water filter; laborious to filter gallons, but an option to extend our stay.
Just my take and your needs may dictate carrying less water.  Interesting to read this discussion.  And of course I might be wrong. :D
Phil
  • 2
#12 XJINTX
XJINTX
  • 552 posts
  • LocationEddy, TX
Posted 02 October 2017 - 12:42 PM
Phil, I totally agree with your position. If I'm on a off grid trip I always fill my tanks when available even if only used a few. Just as I try and top off with Diesel when I can just in case.. However here in TX we do a lot of just weekend getaways to National Forests, COE primitive and such. No where near off the grid and facilities are usually close. Just nice to have enough water on board to make coffee and such. I just don't like leaving water in my tanks even if only for week or two. It's just a waste to drain a mostly full tank because I was prepared. The flow meter helps me to gauge and not waste.
#13 fireball
fireball
  • 222 posts
  • Locationcentral PA
Posted 03 October 2017 - 02:49 AM
I'm not sure why they don't just route a cutout into the cabinet housing the water tank and let you physically see the water in the tank!  I've been meaning to do that but the most we've stayed out at one time without access to supplies was 4 days.
#14 Mickey Bitsko
Mickey Bitsko
  • 193 posts
Posted 03 October 2017 - 03:23 AM
Kind of late to the discussion but, one way to check and post a note, fill the tank then drain a couple gallons at a time,note guage repeat till empty, save the water, refill tank. No wasted water and post findings in camper. Seems easy enough.
Mickey
#15 DanBuffalo
DanBuffalo
    Newbie
  • Pip
  • 1 posts
Posted 03 June 2022 - 04:15 PM
Had this same question regarding my 2021 Hawk (with water heater).  So I ran this experiment with the water heater out of the loop (I closed off both the upper and lower water heater drain cocks):
1. Truck placed on level ground.
2. Filled the empty 20 gallon tank, 1 gallon at a time, until tank was full, and monitored
the "Full-2/3-1/3-E" inside red-light meter after each gallon added.
3. Opened the small drain cock on the outside of the camper, measured 1 gallon outflow one gallon at a time and concurrently monitored  the meter.
4. Continued this process until drain outflow completely stopped, recording the results at each gallon.
5. Put the camper on a steep grade, aft end pointing downwards, and measured the remaining outflow.
This experiment gave me two sets of readings (on filling, and then on emptying).  I ran the experiment twice, and got four sets of readings.
Being a retired hydrologist (This is why I had time to run this experiment :rolleyes: ), I expected exactly identical readings each time, but this was not the case which I thought was peculiar. Here are my findings (averaged):
                  Min    Max
Full Light:   16  –  20    gallons remaining
2/3 Light:    11  – 15.5  gallons remaining
1/3 Light:     4   – 10.5 gallons remaining
  E   Light:    0   –  3.5  gallons remaining
                     +6 gallons in WH
Based on these results, I never fire up the water heater after the "E" light comes on, even though, hypothetically, there may be 3.5 gallons in the tank and 6 gallons in the water heater.
Hope this is helpful.
#16 craig333
craig333
    Riley's Human
  • 8,022 posts
  • LocationSacramento
Posted 03 June 2022 - 04:43 PM
Heck, its more accurate than I expected :)
#17 wicked1
wicked1
  • 190 posts
Posted 08 June 2022 - 01:20 PM
Here is the new control panel I made up to show the water level amongst other things:
Rando,
Did you design/build that?  And the panel for it?
If so, are you an EE?
The panel looks like modular synth panels I build....
It looks great...  I have many questions.. well, since I've already gone OT, I guess it's a little microcontroller of some kind, and you've programmed it to monitor and display the temp/water/voltage?
-just realized I'm replying to a 5 year old post... But still wondering.
Edited by wicked1, 08 June 2022 - 01:21 PM.
#18 AWG_Pics
AWG_Pics
    Into the Great Empty
  • 1,197 posts
  • LocationOregon
Posted 08 June 2022 - 02:41 PM
                  Min    Max
                     +6 gallons in WH
Very interesting. Makes a lot of sense. Thanks for doing the careful measurements and sharing the results.
lived for several years each in Montana, Utah, Idaho, Texas, Washington, Oregon.
2019 Tundra, Hawk.
https://www.flickr.c...hotos/awg_pics/
#19 UncleDougie
UncleDougie
  • PipPip
  • 27 posts
  • LocationChandler, AZ
Posted 20 June 2022 - 09:30 PM
Why make it complicated.
Fill the tank from 1 gallon bottles as needed.
I agree. KISS "Keep It Simple Stupid" empty the tank and then get a 5-gallon fill bucket and fill. Then make your own marks on the next the little view port with 5-gal marks.
