On our Hawk, the previous owner forgot to undo one of the clamps that hold down the roof, causing that part of the roof to be distorted/bent, has anybody found a simple way to repair this?? I was thinking of holding down the opposing areas somehow, then using a hydraulic jack to push up where it is bent down, forcing that area of the roof back up into place. Has anybody had experience with this?? Or can recommend a place to get this repaired?? We are from Canada, heading down to Arizona through I-15, we are a bit flexible as to where we can to to take this to get repaired. Northern California is very far from where we are going
#1
Posted 17 November 2017 - 04:02 PM
#2
Posted 17 November 2017 - 04:19 PM
Interesting!
#3
Posted 17 November 2017 - 04:27 PM
There is a dealer in Jackson hole Wy. But your best bet would try find out who 4wc campers would recommend. I've herd on this forum Stan can be very accommodating.
109 Pioneer Avenue, Woodland, CA 95776
Phone: (530) 666-1442
Fax: (530) 666-1486
E-mail: CustomerService@fourwh.com
http://www.fourwh.com (Website)
Russ
#4
Posted 17 November 2017 - 05:12 PM
You might be surprised what you can do with just a couple blocks of wood, a little muscle power and/or a dead blow hammer. Aluminum can be tweaked quite easily unless there is a hard crease in it.
#5
Posted 17 November 2017 - 06:57 PM
Thats what I used when the dog forgot to undo one of the latches.
#6
Posted 17 November 2017 - 07:12 PM
... I was thinking of holding down the opposing areas somehow, then using a hydraulic jack to push up where it is bent down, forcing that area of the roof back up into place. .
Or maybe with the top down, place a block under the "low" spot and resting on the camper body and jack down the adjacent area using say, a garage beam or header to jack against.
#7
Posted 18 November 2017 - 01:45 AM
I straightened the roof on my old 2002 Hawk with two wood blocks 2x4 and a BIG C-clamp. Bend was in the front so I clamped from below the overhang to the top of the roof. The aluminum moves easy.
Bill Harr 2005 Tundra and a 2013 Hawk custom interior.
#8
Posted 18 November 2017 - 02:07 AM
I think Bill has the right idea of using a block of wood under the bent low spot, and then you could use pipe clamps (You can make them any length you need) on each side of the bend, with one end of the pipe clamp on the bottom edge of the camper body that hangs over the truck bed, and the other end of the clamp on the roof. It won't take much, as there is just the outside trim, and a one inch tube on the outside of the roof frame. Two clamps long enough, with slow tightening would probably get the job done.
I'd probably suggest using a piece of wood where the clamp jaw rests on the roof, to prevent any small indentations on the roof skin from the clamp.
Poky
Edited by PokyBro, 18 November 2017 - 02:09 AM.
1999 F250 crew cab SRW, 7.3 Powerstroke TD
1981 Grandby shortened to a Hawk
Build thread / https://www.wanderth...by-into-a-hawk/
#9
Posted 05 December 2017 - 11:51 PM
I am going to try this next week at a friend's shop, he has everything needed to do this, it should work (in theory)
Also tagged with one or more of these keywords: Hawk, roof, repair
