Water Tank Mangement
water tank water tank
31 replies to this topic
#1 Santiam Camper
Santiam Camper
  • PipPip
  • 28 posts
  • LocationCorvallis, Oregon
Posted 05 January 2018 - 09:18 PM
I have a 2017 FWC Fleet and I have some questions about managing the water tank during the camping season when camping in areas with out water connections available.  I don't have the hot water option installed.
*  Do you always keep it topped up to the full 20 gallon capacity?
*  Do you use water from the tap or do you fill from purchased water bottles?
*  During the camping season do you empty it after each trip or do you just add water as needed to refill?
*  How often during the season do you drain and sanitize the tank?
Thanks for replying.
Mike
Mike Madden
2017 Nissan Frontier
2017 Fleet
#2 craig333
craig333
    Riley's Human
  • 7,753 posts
  • LocationSacramento
Posted 05 January 2018 - 09:43 PM
When possible. Tap water. Refill as needed. Yearly sanitization.
#3 longhorn1
longhorn1
    Ouch, that stings!
  • 2,812 posts
  • LocationCarmel, Indiana
Posted 05 January 2018 - 10:16 PM
I fill according to the trip length. We use a camping water softener and white camping hoses, can be purchased at Camping world. On an 18 day trip to Colorado, we had approximately 1/4 of a tank left. When we have water available we use a pressure gauge and small water filter also purchased at Camping World. We use the tank gauge and check it every couple of days. Depending how many days between trips will help determine whether we empty the tank. If we are going to remove the camper, we empty the tank so we don't have a weight issue and/or have the wood bottom pull loose from the frame. We winterize and in the spring flush out the tank and lines and then add 1/4 cup of bleach to sanitize, flush out and fill.
Edited by longhorn1, 05 January 2018 - 10:38 PM.
http://texaslonghorns01.blogspot.com/
Ford F-250 Long bed, 2014 Grandby
#4 Vic Harder
Vic Harder
    Doctor Electric
  • 4,415 posts
  • LocationCalgary, Alberta
Posted 05 January 2018 - 11:07 PM
Longhorn,
Do you save and reuse the antifreeze?  When do you add the bleach?  Before flushing the Antifreeze?  In the fall?
Vic
2015 Silverado 3500 crew cab 8' bed Diesel
2012 ATC Puma Shell build - https://www.wanderth...012-puma-build/
Power considerations thread - https://www.wanderth...e-power-scotty/
Building out an electrical system - So, you want to setup a good electrical system in your camper? - Electrical, Charging, Solar, Batteries and Generators - Wander the West
#5 klahanie
klahanie
  • Validating
  • 932 posts
  • LocationSW BC
Posted 06 January 2018 - 12:14 AM
* Rarely, depends on trip length. We carry separate "drinking water" to increase capacity. Sometimes I'll partially drain just before last day going home to reduce wt - and hope I don't meet someone who needs it
* tap, using potable water hose that we carry
* yes
* usually only end of season
we also carry a largish funnel to assist refilling using a bucket or jug.
#6 longhorn1
longhorn1
    Ouch, that stings!
  • 2,812 posts
Posted 06 January 2018 - 01:16 AM
Vic, since there can be 2 gallons of water left in the water tank, it becomes diluted. I might get a couple gallons and reuse them with brand new antifreeze. I add a lot of water and run it through the lines. I will keep adding water to get the antifreeze out. I will then add the bleach and run the bleach water through the line
Then one final flush and fill the tank. 20-30 minutes tops
#7 Outnabout
Outnabout
  • 270 posts
Posted 06 January 2018 - 02:57 AM
What process do people use to flush the tank? When I drain I use the valve on the outside but it takes a really long time. Is this the flush procedure? Thanks for any advice.
#8 camper rich
camper rich
  • 349 posts
Posted 06 January 2018 - 04:12 AM
When in Baja we fill the tank with purified water from jugs we purchase, actually we go to a place where they sell the water and refill the one jug we carry with us.  I use two 10 foot white hoses, a clear plastic nozzle and a 12 V water pump.  When filling from a hookup at a campground we use the pressure reducer and a water filter, the hoses and the nozzle.
I usually empty it after every trip and we sanitize it once a year.  My wife doesn't like me using antifreeze so I work very hard to be sure as much water is out of the system as possible so it doesn't freeze.  So far, so good.
#9 longhorn1
longhorn1
    Ouch, that stings!
  • 2,812 posts
Posted 06 January 2018 - 01:06 PM
Outnabout, since the tank holds water, I add about 5 gallons and then empty at the rear of the camper. I do this a couple of times, then turn the pump on and open the cold and then the hot faucet to run things through the lines, pump, hot water tank, and do the same for the outside to get remaining antifreeze out. After I do that I will add 5 gal +/- and 1/4 cup of bleach added to a jug of water and then poured into the tank. I run water through the lines, pump, hot water tank, and outside shower. Hope that helps. As I said maybe 30 minutes to get everything flushed and tank filled. jd
Edited by longhorn1, 06 January 2018 - 01:07 PM.
#10 rtpvibes
rtpvibes
  • 103 posts
Posted 06 January 2018 - 02:10 PM
I have had two fc and never use antifreeze . They both had it when I bought them. End of season I empty the hot water tank and empty tank as much as I can . Live in New England . Never had issues. And clean tank with vinagar . I use pure water filter on faucet . Easy way
  • 1
Also tagged with one or more of these keywords: water, tank, water tank
