Older Hawk won't fit in newer Chevy
Hawk fit Silverado
17 replies to this topic
#11 ottorogers
ottorogers
  • 335 posts
  • LocationSaskatoon, SK Canada
Posted 21 January 2018 - 05:10 PM
I have a 2014 Hawk originally on a 2014 Tundra, bought a 2016 Silverado with the rounded bed at the gate so I took 2 sheets of 3/4 outdoor plywood and sealed them together and placed them under the camper, this raised it enough to give it about 1/4 inch on each side of the rounded bed.
2 sheets of 3/4” plywood ads a lot of weight, right??
#12 Bill D
Bill D
  • 981 posts
  • LocationEdmonton, Alberta, Canada
Posted 21 January 2018 - 05:28 PM
That's why many members use foam insulation board.  It also adds R value.
#13 hkyfsh
hkyfsh
  • PipPip
  • 29 posts
  • LocationEastern Sierra
Posted 25 January 2018 - 10:43 PM
Yeah I guess it would add some additional weight.  I wasn't worried about the weight and it was a last minute thing as I had the dealer drill holes in the bed for the eye bolts as part of the deal and we noticed the camper wouldn't seat when they were done so that was my quick solution.  It works fine.  If you are worried about the weight its probably not the best alternative.
#14 rustytinbender
rustytinbender
  • 62 posts
  • LocationSE Wisconsin
Posted 26 January 2018 - 02:54 AM
I bought I used Hawk for my 2011 chevy silverado from a person who also had a 2011 silverado. The factory built his with a 'chevy notch' to accommodate the rounded tailgate opening and keep from having to shim up the camper. Perhaps FWC could provide the details of what they do otherwise the foam board to shim it up seems like a reasonable lightweight idea.
#15 Mayday
Mayday
  • PipPip
  • 23 posts
  • LocationCentral Coast, CA
Posted 16 August 2019 - 03:27 AM
Did you ever end up finishing the project? I'm about to pick up my Hawk with a 13 Silverado that does not include the 'chevy notch' in it. Curious to see what needs to be modified for it to sit in the bed.
#16 kitmann
kitmann
  • PipPip
  • 13 posts
Posted 16 August 2019 - 03:35 PM
Mine is an older Hawk.  Cut notches on both sides and filled in.  On furnace side was just enough clearance.  Also had to raise as noted by others and shown with 2x4s.  I have a narrow water tank between cab and camper and run a water line to back of camper in the space created under the camper.
#17 Mayday
Mayday
  • PipPip
  • 23 posts
Posted 20 August 2019 - 08:55 PM
Thanks for the input everyone. I picked up my hawk and ended up going with the 2 inch foam in the bed as a platform. Worked out great.
#18 smlobx
smlobx
    Lost again
  • 1,529 posts
  • LocationNorth Carolina
Posted 24 August 2019 - 10:28 AM
Good choice!
Eddie
KO4CPL
Also tagged with one or more of these keywords: Hawk, fit, Silverado
