Solar wiring discovery - 2017 Hawk
17 replies to this topic
#11 pvstoy
pvstoy
  • 2,043 posts
  • LocationCarson City, NV
Posted 30 March 2018 - 10:47 PM
Take the negative for the BVM and move it to the other side of the shunt with the load and MTTP.
One side of the shunt should only have the negative to the camper battery and the other side has all the other grounds.
Patrick
2015 FWC Hawk Flatbed
#12 pvstoy
pvstoy
  • 2,043 posts
Posted 30 March 2018 - 10:49 PM
Ok I was looking at the drawing and the BVM is not on the negative post but a small hookup wire on the side of the shunt?
Patrick
#13 Karlton
Karlton
  • 78 posts
  • LocationNorth Idaho
Posted 01 April 2018 - 02:58 PM
Thanks, pvstoy - I got it figured out.  I updated the image diagram a bit, and hope it is helpful for someone else considering wiring a Hawk for solar.  Red is positive, black is negative.
Best
Edited by Karlton, 04 August 2018 - 11:21 PM.
2017 Hawk, 2007 Tundra TRD, Boise Spring Works leaf spring upgrade
#14 pvstoy
pvstoy
  • 2,043 posts
Posted 01 April 2018 - 03:36 PM
Looks clean. Now that I have been reasearching Victron BVM I now understand that is a phone plug in wire set from the shunt to the BVM. Thanks for the diagram.
Patrick
#15 Karlton
Karlton
  • 78 posts
Posted 01 April 2018 - 08:08 PM
Cool - both the MPPT and BVM are Victorn products.  I saw your other post regarding wiring and it looks like a few folks suggest the Victron products.  I'm pleased with the set-up.
#16 So Cal Adventurer
So Cal Adventurer
  • 368 posts
Posted 30 September 2019 - 05:22 PM
I have a Victron Smart MPPT 100/30 controller and accidentally touched some wires together while moving it and think I may have shorted it.
For those mentioning it has a fuse... where?? Inside?
Thanks
Edited by So Cal Adventurer, 30 September 2019 - 05:23 PM.
Follow My Shenanigans: instagram.com/campermccampface
#17 Old Crow
Old Crow
    Searching....
  • 816 posts
  • LocationSouth Central PA
Posted 30 September 2019 - 05:39 PM
Thanks
A search for 'fuse' in this manual says:
(Page 12)
Charger Does Not Function:  Reverse battery connection:   Non replacable fuse blown. Return to VE for repair.
and (page 13)
Protection: Battery reverse polarity (fuse, not user accessible), PV reverse polarity, Output short circuit, Over temperature...
Edited by Old Crow, 30 September 2019 - 05:41 PM.
  • 1
'01 FWC Hawk shell on a '13 Tundra Double-Cab  + '19 Ford Transit van with Quigley 4x4 option
#18 So Cal Adventurer
So Cal Adventurer
  • 368 posts
Posted 10 October 2019 - 12:05 AM
Thanks Old Crow
This was a dummy thing on my end, kinda
Had everything apart and forgot the FWC wiring is backwards for the Zamp so I connected it wrong.
Forgot all about that, switched it around and all is well
