I use the same L&I table. ie Table figure for min pressure for my weight when starting out plus 2-4 psi for highway (measured cold). Off highway I might deflate to the same table figure (but as hot) then "maybe" deflate another 5psi as a possible second step down. After that I reduce speed (even more) to improve comfort.
It's not uncommon for me to see a 10psi rise from cold to hot for both front and rear tires. So for eg 45/60 cold + highway use bump + any elevation gain + any ambient air temp rise + a couple kms of bumpy gavel and I might be at 58/73. I take that down to 45/60 (measured hot). EDIT: only for comfort, as desired.
Our rig is heavy compared to a lot on here and has relatively high spring rates so airing down helps immensely for comfort off highway. And we drive thousands of kms of gravel per year.
I have two reasons for not usually going lower. First, invariably the road surface changes and I may be able to drive faster a few kms down the road. Here I don't want to be too underinflated for the speed that might be being driven (under steer can sometimes occur and possible loss of control). Second I've gone lower and the tires can get hot, which I don't like. I remember one time we were days from home and a long way in from the highway and the fronts (tire, rim and hub) were warm enough to concern me. I was worried about the wheel bearings.
So I'd also use temp as a guide. If the air coming out of the valve is hot enough to burn my wrist then, yeah, that's low enough.
EDIT: YMMV, weight, speed, road surface, tire rating are all factors
Edited by klahanie, 08 May 2018 - 02:50 AM.
