I am looking for the brand/model of amber led clearance light FWC uses. I have 2015 Grandby.
From the markings on the light and a google search I think it is a 168 a Made by Peterson.
I was resealing the light because of a leak and cracked the plastic around the screw hole.
I can call on Monday but hoping to replace ASAP and I live a good distance from any supply shops.
If you click on the upper left photo on this Peterson web page for more detail, the photo that comes up appears to show the same markings. And if you click on the right photo, you should be able to match that to the back of yours. That would confirm it as a Peterson 168A (as you say).
And if it is indeed a Peterson 168A, it's available on Amazon here.
The photo in that Amazon listing isn't the greatest and I don't see any SKU or numbers other than the part number 168A to confirm. You may want to double check that yours mounts on 1 and 15/16 inch centers before ordering.
Also- a search for Peterson 168A shows multiple hits and lower prices.
