#91
Posted 12 January 2019 - 09:15 AM
Why not use a similar approach for mounting the 8020 to the jack brackets?
#92
Posted 12 January 2019 - 03:49 PM
Good question and good on ya for thinking about it. If the rails were very rigidly connected to the brackets, and a lot stiffer than the aluminum frame, then it would stiffen up that part of the camper. That could fail the brackets or the camper frame where the brackets attach over time, especially if a fatigue crack starts. However, I'd guess that the 8020 attachments are kinda "soft", but haven't really looked at it carefully. You could avoid the whole problem by using rails that are not too macho, and attaching them in such a way that they are somewhat flexible.
I am not sure I understand why this is an issue, but the superstrut is pretty darn flexible.
2014 Tacoma, 2012 Eagle
#93
Posted 12 January 2019 - 04:23 PM
There's a range of things that could go wrong with a rigid connection between the brackets. Thermal expansion/contraction, flex in the camper's frame, flex in the connecting parts, etc., etc., etc.
I'm not to inclined to worry about it, the whole of the system is flexible enough that some considerable distortion, enough so that you've probably got other problems by that point, would need to happen before it would be a concern.
That said, it is easy enough to fix one end of the strut(s) rigidly to a jack bracket and allow the other end to have some float. The floating end could be simply that there is a spacer such that, it the case of 80/20 extrusions, the bolt into the t-nut can't completely clamp the extrusion when run down tight. That would allow the extrusion to slide on the t-nut at one end only.
Where does that road go?
#94
Posted 12 January 2019 - 04:27 PM
I see now.
#95
Posted 18 January 2019 - 07:07 PM
This is just a simple one, but I bolt on two "U" hangers on the bottom hole of each rear bracket. It works great to hang packs, hunting and fishing vests, jackets, etc. while in camp. I do like the table idea.
2005 Tundra 2013 Ocelot "Ridiculously comfortable"
2021 Tundra 2022 Cougar Shell Built Out "Even more ridiculously comfortable"
#96
Posted 18 January 2019 - 08:54 PM
We have 2 ~6' lengths of 80/20 running between our rear jack brackets, with both ends secured tightly. No issues in the 3 years it has been on there, so I agree that this is likely nothing to worry about.
2016 Fleet Flatbed
2016 Toyota Tacoma
#97
Posted 18 January 2019 - 10:44 PM
Yeah, I like hanging things from the brackets when camping. Here are the eye bolts and awning brackets I'm using currently...
~Jim2000 Tundra AC- 2000 FWC Ranger
2017 Tundra DC - 2017 ATC Panther
#99
Posted 18 January 2019 - 11:19 PM
Rando -
Are you using the 1' or the 1.5" 8/20? I like what you have done!
#100
Posted 18 January 2019 - 11:22 PM
If that is directed to me, it's 1 inch by 3 wide.
Also tagged with one or more of these keywords: ski, jack bracket, storage
