Insulating the floor of your camper
17 replies to this topic
#1 smlobx
smlobx
    Lost again
  • 1,529 posts
  • LocationNorth Carolina
Posted 06 October 2018 - 10:05 AM
We hope to be able to do some colder weather camping and I was thinking about how to maximize the thermal efficiency of our camper.
One of the things I realized is that there doesn't appear to be any insulation on/under the floor... so I decided to add some. First, I looked under the camper and realized that the underside of the rig has firing strips running the length of the camper. In my case they are 1 1/2" thick. I decided to install solid rigid foam board to fill the gaps between the runners and bought a sheet of Styrofoam insulation..
https://www.homedepo...ng-4C/100297916
I then measured the distance between the runners and ripped the board on my table saw..NOTE the distances between the runners were all different....Measure twice-cut once!
I attached the foam board to the bottom of the camper with the appropriate foam board adhesive by applying the foam to the board and then lowering the camper onto the precisely placed foam boards. I'm letting them sit overnight to bond completely and I should be good to go.
The whole project cost less than $30 and only took an hour. The foam board is impervious to moisture and should last as long as the camper. It provides us with an additional R-7.5 and probably weighs less than 5 pounds.
The foam board pieces sit flush with the runners so they don't affect the height of the camper.
Edited by smlobx, 06 October 2018 - 11:16 AM.
  • 2
Eddie
KO4CPL
#2 Happyjax
Happyjax
  • 1,444 posts
  • LocationMaryland
Posted 06 October 2018 - 12:58 PM
That should really help you stay toasty!
#3 smlobx
smlobx
    Lost again
  • 1,529 posts
Posted 09 October 2018 - 05:25 PM
Here's a not so great phone picture of the foam lying flush to the bottom of the runners...
Eddie
KO4CPL
#4 Scott_H
Scott_H
  • PipPip
  • 29 posts
  • LocationPark City, Utah
Posted 04 December 2019 - 03:17 PM
I was considering doing this for my Milner.  Would love to know if you are able to tell a difference with this mod? I was thinking of using some velcro or a more temporary way to keep in place when the camper is off of the truck.  Any thoughts on this?  Do you also use a rubber map between your truck bed and Everest?  Thanks!
#5 knoxswift
knoxswift
  • 219 posts
  • LocationAshburn, Virginia
Posted 04 December 2019 - 03:38 PM
I did this mod. I was able to tell a difference. The floor doesn't feel as cold as it did with the bare feet test...lol
#6 Advmoto18
Advmoto18
  • 1,083 posts
  • LocationCoastal Low Country, SC
Posted 05 December 2019 - 12:26 AM
Eddie, great idea!
Our camper is sitting on the jacks, so a good time to add the rigid foam.
I stumbled upon this concept and it has worked great for us.
This sleeping bag pad from WalMart cut to fit.  We camped on the Alvord (OR) in a blizzard.  The inside of the camper was nice and toasty;  we could walk on the pad bare footed, that warm and comfortable.  I lifted the pad and the camper floor had to be near freezing temp.
Bill
Edited by Advmoto18, 05 December 2019 - 12:29 AM.
South Carolina Low Country.
#7 Durango1
Durango1
  • 532 posts
Posted 06 December 2019 - 05:22 AM
I used the exact same foam board from Home Depot to fill in the spaces on my last two FWC flatbeds. However, I ordered them with only one 'runner' so we only had 3/4" to work with. (It kept my overall height lower.) Does it work? Don't know but definitely worth the 20 bucks or sure to know we did the best we could! :)
#8 pvstoy
pvstoy
  • 2,768 posts
  • LocationCarson City, NV
Posted 06 December 2019 - 05:38 AM
I was wondering how that insulation got there...thanks Steve!
Patrick
2015 FWC Hawk Flatbed
#9 smlobx
smlobx
    Lost again
  • 1,529 posts
Posted 06 December 2019 - 04:56 PM
Hi Scott-
Yes we do use the rubber mat under our camper that Hallmark provided us but doubt that it adds any insulative qualities as the air gap provided by the campers runners allowed cold air to circulate under there.
Eddie
KO4CPL
#10 LosAngeles
LosAngeles
  • 178 posts
Posted 07 December 2019 - 01:41 AM
It is my understanding that in current (new) Hallmarks there is some insulation in the floor. If I recall correctly.
