Optimal location for roof rack cross bars
fwc roof rack yakima thule eagle roller
  • Please log in to reply
2 replies to this topic
#1 OffTheGridMaps
OffTheGridMaps
  • PipPipPip
  • 35 posts
  • LocationWhitefish, MT
Posted 06 May 2019 - 05:39 PM
I've recently purchased a 2005 FWC Eagle (2-piece roof) and would like to add a roof rack to carry paddleboards, canoe, etc.
What is the optimal front-to-back location to position the roof rack cross-bars?  One consideration I have is loading my canoe (~70lbs).  I thought I might be able to add a roller bar to the rear crossbar, so that I could self-load/unload.  If the roller bar is wide enough (~36") and set far enough back, I was thinking I might be able to flip the canoe upside down, load from the rear, and just push/slide the canoe onto the roof without coming into contact with the camper.
Also, any recommended roller roof rack setups?  I found a couple from Yakima and an off-brand:
Anything else on the market that people have used?
2005 FWC Eagle | 2003 Toyota Tundra
OffTheGridMaps.com - Maps of Montana's best outdoor recreation activities
#2 jimjxsn
jimjxsn
  • 599 posts
  • LocationRoxborough Park or Buena Vista CO
Posted 06 May 2019 - 07:51 PM
I had a FWC Ranger with the factory canoe rack and now have an ATC Panther with the Yakima tracks.  I like having the rack on the tracks because you can adjust the space between the bars to fit your needs.  On the ends works great for a long canoe but not for most other items.
For loading I use a Yakima outrigger which is similar to the Yakima boatloader.  You can get an idea from these pics -
Thule photo -
Here are some poor pictures of it on my camper.
I just prop the bow onto the outrigger with the stern on the ground.  Then I grab the stern and swing it over onto the rack.
With my old camper with the factory canoe rack I even made an outrigger out of smaller diameter square tube.
I found that method better than trying to load from the back.
**And it really helps to have crossbars close to as wide as the camper.**
  • 1
~Jim
2000 Tundra AC- 2000 FWC Ranger
2017 Tundra DC - 2017 ATC Panther
#3 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,959 posts
  • LocationCalgary, Alberta
Posted 07 May 2019 - 05:59 AM
What about making some brackets and using one of these?
https://www.grainger...9&filters=attrs
Also tagged with one or more of these keywords: fwc, roof rack, yakima, thule, eagle, roller
