Vic I looked at the Renogy DC to DC charger.
Would that be instead of the Isolator?
Posted 28 June 2020 - 08:55 PM
Posted 28 June 2020 - 10:31 PM
Frank, any DC-DC charger will replace the isolator, and/or rather make the isolator inoperable. This is a downside of the DC-DC charger as it won't allow the solar panels to charge the truck battery. (although rando has posted a workaround using a relay and switch that bypass the DC-DC charger if wanted).
The Renogy requires that you add some more smaller wires (signalling that the truck is running, for example). The Victron is smart enough to not need any other wires than what you have.
Posted 28 June 2020 - 10:42 PM
Thanks Vic for taking time to give some info.
Not sure what I'll do yet.
My work around is to just run the fridge on propane while on the road.
My use of the 3 way is basically as a freezer.Starting a trip with it full of
whatever we need of frozen plus some containers of frozen water.
That method works for weeks on a trip.
The Truckfridge is our daily reefer unit.
Vic what actually does the BlueSea 7600 unit do and or replace?
Posted 29 June 2020 - 02:58 AM
The BlueSea 76xx replaces the factory Sure Power 1314a
Posted 29 June 2020 - 06:00 PM
Vic does that BlueSea 76xx work the same as the Isolator
that replaced the Surepower1314?
Will the BlueSea 76xx solve the charging issue ?
Or do I still need a DC DC charger?
Sorry to keep asking maybe the same question.
I am just looking for an easy fix.
Thanks for all your advice.
IMG_4882.jpeg 85.67K 7 downloads
Posted 29 June 2020 - 07:51 PM
Yes, your AOPEC isolator does the same thing as the SurePower and as the Blue Sea
IF you are going to get the DC-DC charger you do NOT need any isolator at all
EASY in your case would be a victron orion. Less wiring for sure.
Posted 29 June 2020 - 10:11 PM
Thanks Vic.I appreciate all the info you have provided.
Posted 29 June 2020 - 11:55 PM
Keep us posted...
Posted 30 June 2020 - 09:43 AM
Vic,
Not sure what you mean about the D250SA not allowing charging by solar panels.
But, I do acknowledge the point about its 20A capacity.
Cheers.
Edited by MidAtlantic, 30 June 2020 - 09:46 AM.
Posted 30 June 2020 - 01:18 PM
Not so much that it won't allow charging by solar panels, but that it won't allow charging of the truck battery(ies) by the camper's solar panels. It is a one direction charging device, not a bi-directional device like the later dual sensing ACR/VSR's are.
Occurs to me that an older, single sensing ACR/VSR wired in parallel with the DC-DC converter and biased towards the truck batteries would allow automagical solar charging of the starting batteries while not interfering with the DC-DC converter's charging of the camper batteries.
The way that I see it, 40A from a ~120A rated alternator shouldn't be working it too hard.
