Correct (and safe) pressure varies with the situation and the substrate. In deep sand you could go all the way down to one bar (14.7 psi) with your combination, although 18-20 will float you across most sand. For general driving on trails, to increase comfort and traction and decrease stress on the vehicle, try around 40-45 if 60 is your pavement pressure. Same or a little lower for mud and snow. There's more detailed information here.
All good advice...and understood...I never thought of "stress on vehicle" with higher pressures off road; excellent point, broken metal is tough to fix on the road..my "higher pressures off road" comes from off road motorcycle riding to prevent pinch flats and punctures....but on the bikes my speed is much higher than in Tundra...
Non sequitur .... but Tundra has Firestone air bags, rear Heli sway bar and tires are LT 285/85 R16 [E rated]..Warn winch with receivers fore and aft.
Calls to WRT rangers and they keep coming back to carrying 2 sets of tire chains...not going to happen for me...if we encounter anything that could be a "stop right there" and would necessitate chains, we turn around or sit there and wait out drying of mud or melting of snow if those are the issues..sand out near South Coyote/White Pocket might need lower tire pressure but that is about it...I also do not drive on wet clay, have in past lifetime had tires gumboed up with clay and zero traction....
Anyway...thanks so much for the input you folks have offered...it is appreciated..
Phil
