Vent fan options (not pre wired)
#1
Posted 21 February 2020 - 05:16 PM
#2
Posted 21 February 2020 - 07:39 PM
My understanding is all FWCs came pre-wired for fans. When I bought my used 2000 Eagle I had to take the old non-electric vent out and poke around to find my wires. Call FWC if you can't find them.
If there are no wires, I would try to run some small wires from the nearest light fixture. I believe the lights are on the same aluminum rib as the vent opening. I bet if your careful you could probably fish the wires through the insulation from the light to the vent.
2017 Toyota Tacoma with 2000 FWC Eagle
"The nut behind the wheel is the most important one. Don't forget to snug yourself up every once in a while." John D & ri-f
#3
Posted 21 February 2020 - 08:36 PM
Replaced my Fantistic Fan (vent only) with a Maxxair in my 1999 Eagle. Thankfully it was pre wired . Pull the old one to look?
Otherwise a simple exchange.
