2009 Eagle swap out to a fan
fan upgrade prewired
6 replies to this topic
#1 Greeneggsslc
Greeneggsslc
  • PipPip
  • 20 posts
Posted 24 February 2020 - 07:50 PM
Good day everyone. I have a 2009 Eagle that I'm pretty sure is prewired for a fan. We just replaced the wiring to the lights and there was 4 wires up behind the front panel. I'm guessing the other two go to a fan. Can anyone confirm this? If so we have a vent already. which we pulled out (with out messing with the roof seals) to see if we could see any wiring, but we couldn't. So I'm a bit confused and hope someone knows what I'm talking about. If those wires are for a fan then does anyone know how to locate them with out messing with the outer most part of the vent that has a beautiful seal that doesn't leak.
#2 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,940 posts
  • LocationCalgary, Alberta
Posted 24 February 2020 - 10:20 PM
If you undo the screws on the inside flange of the roof vent, it will drop out revealing the power wires.
  • 1
#3 Stan@FourWheel
Stan@FourWheel
  • 2,376 posts
  • LocationWoodland, CA
Posted 24 February 2020 - 10:23 PM
Should be pre-wiring tucked up in there somewhere.
We have been pre-wiring for roof vents fans since the 1990's.
Like Vic mentioned, remove the beauty ring (square trim piece) around the roof vent inside the camper and look around for 2 wires coiled up.
Woodland, CA 95776
www.fourwh.com  ---  e-mail = stan@fourwh.com
#4 bfh4n
bfh4n
  • 235 posts
  • LocationLovingston, Virginia
Posted 25 February 2020 - 03:34 AM
I replaced a non-fan vent with a motorized one and the wires were right there, once the inside trim was removed. No need to remove the outside part of the vent, just installed the motorized assembly in it..
The wire colors were reversed between the camper and the fan. I believe the ground was black in the camper and white on the fan. Or vise-versa. Probably wouldn't hurt the fan, if it's not the kind with any electronics, but the IN-OUT switch would work backwards.
I seem to remember having to cut away a little bit of the plastic of the trim ring to create a place for the wires to enter. Also, had to cut and re-splice the wire to the switch which turns the fan off when the vent lid is closed. All very easy and obvious.
- Bernard
2014 silver Fleet front-dinette
2007 Tacoma Access Cab 4WD TRD V6 6-speed
#5 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,940 posts
Posted 25 February 2020 - 03:37 AM
As Bernard says, the polarity was "reversed" or rather, it was using the RV standard of Black = positive.
#6 Oilbrnr
Oilbrnr
  • 110 posts
  • LocationFlagstaff & Scottsdale, AZ
Posted 25 February 2020 - 05:11 PM
Would the pre-wire be present for both vents if so optioned or just one?
  • 2016 Power Wagon - King/Thuren/Carli/Air Lift/Daystar suspension
  • 2017 FWC Hawk
#7 Stan@FourWheel
Stan@FourWheel
  • 2,376 posts
Posted 26 February 2020 - 04:43 AM
Both vents. (Front and Rear)
Woodland, CA 95776
Also tagged with one or more of these keywords: fan, upgrade, prewired
