I’m trying to get this picture to upload in the proper direction
I see a problem, potentially caused by the dual connection on the ACR terminals That can and probably has, confused you.
If i read this right, the left connector on the ACR goes to the +ve buss bar and from there to the 12V fuse box. AND to the +ve terminal of the camper battery via a 60A breaker. That's fine as is, but it would be cleaner if the wire from the 60A breaker went to the +ve buss bar so that there is just the one wire coming to the ACR from the camper side.
Then, on the right side of the ACR you go to the Truck battery via a 60A breaker, AND ALSO directly to the +ve terminal on the camper battery. That last connection is the problem = it totally bypasses your ACR as it directly links the two +ve terminals of the ACR.
