Posted 15 May 2020 - 07:21 PM
Thanks Ckent for your info. The AGM battery is a three stage charge. After watching a blog, video, I learned that the Victron Smart Controller app, under History shows a Graph with a 3 stage charging profile,indicated by the 3 different color tones on the Graph. I believe the white tone is bulk. The gray is absorbsion, which is always small. The blue is float. So I've got my 3 stage charging, but the Victron app under setting, Battery, only shows a aborbtion voltage and a float voltage. The bulk and absorption voltages are the same as per battery manufacturer. So the MPPT does separate the 3 stages of charge, it just doesn't allow you to change easy.Here is a link from Victron that I tried, but don't understand.The bulk rate is changed in the battery section in settings by changing the "Max Charge Current" setting which is in Amps. The "Offset" or when it goes into bulk charge is changed by turning on expert mode after you select "user defined" for battery preset. This value in Volts determines how far the voltage will drop from the float voltage value starting the bulk charge state. Anyway, I'm happy with the system the way it works now. I hope this helps someone.
Rich
