Solar Noob Q: [@Costco] Coleman 100w Panel integration
Solar Coleman Costco
  • Please log in to reply
11 replies to this topic
#1 BigRanchInSky
BigRanchInSky
  • PipPipPip
  • 45 posts
  • LocationUtah
Posted 29 March 2020 - 04:06 PM
Well, I'm itching to get my camping on, but staying put for now as per CDC guidelines, there's not much close by, I'd have to drive at least 1.5 hours away to camp right now=pretty cold in the Wasatch Mtns at present...the wife works in health care, so no go for me for now...so there's only one cure for that: Camper upgrades!
Today @ Costco they have a Coleman Solar panel on sale, $129 with free shipping, and I'm wondering how it could be integrated with the 2019 FWC Hawk. See the attached JPEG of the unit.
Since I'm a noob, of course I'd love to just plug the thing into the standard FWC solar extension plug (I believe my solar plug is on the rear of the camper) and away it goes...is there something I need to do before I plug it in? Keep the supplied controller or loose it? I have a 160 Watt system with 2x12V batteries, all stock from FWC as of 2019. I can probably handle finding the right plug adapter and hopefully get the polarity correctly identified when hooking up the plug leads, any info on that appreciated also.
Thank you in advance, I appreciate your ideas!
Edited by BigRanchInSky, 29 March 2020 - 04:13 PM.
______________________________
2019 Hawk / Ford F250
#2 longhorn1
longhorn1
    Ouch, that stings!
  • 2,826 posts
  • LocationCarmel, Indiana
Posted 29 March 2020 - 09:51 PM
Your solar plug on the rear of the camper should be wired directly to your solar controller. Therefore, your portable panel should not have a built in controller and you shouldn't use a portable panel with one. Our 2014 Grandby had 100W Zamp on the roof, with a Zamp controller. When I purchased a portable 80W Zamp panel, I had discussions with Zamp and FWC and they both confirmed the portable panel should not have a controller.
Edited by longhorn1, 29 March 2020 - 09:53 PM.
http://texaslonghorns01.blogspot.com/
Ford F-250 Long bed, 2014 Grandby
#3 BigRanchInSky
BigRanchInSky
  • PipPipPip
  • 45 posts
  • LocationUtah
Posted 01 April 2020 - 03:00 PM
Thanks Longhorn! OK, so take away the controller and get the plug figured out and I should be ready to go, correct? I purchased online, so it won't be here for a few days (hopefully not weeks) and I'll go from there.
Q: Are all solar plugs standard or will I be needing to get a unique plug somewhere?
#4 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,589 posts
  • LocationNortheast Oregon
Posted 01 April 2020 - 04:09 PM
If nothing has changed, I believe FWC uses the SAE connector, and suspect the Coleman may as well.
I am haunted by waters
#5 rando
rando
  • 1,638 posts
  • LocationColorado
Posted 01 April 2020 - 04:15 PM
The solar plugs are not standard.  FWC uses an SAE plug.   You will need to buy a pigtail and splice it onto the wires coming from the solar panel.   You can use a multimeter to measure the polarity of the plug on the side of the camper.
It sounds like you have already ordered this, but if not, a foldable panel is a lot easier to deal with in the limited storage of a truck camper.
2016 Fleet Flatbed
2016 Toyota Tacoma
#6 ckent323
ckent323
  • 1,227 posts
  • LocationSolvang, CA
Posted 01 April 2020 - 08:41 PM
There are adapters available to go between MC-4 and SAE connectors.
https://www.amazon.c...r/dp/B01N1TALFY
1993 Dodge Cummins W-250 Club Cab long bed, 2007 FWC Keystone
#7 fuzzymarindave
fuzzymarindave
  • 255 posts
  • LocationMarin County, CA
Posted 01 April 2020 - 09:38 PM
I'm a solar noob too.  Just a thought, if a portable panel had it own controller; would it not be feasible to rewire the rear plug so that it goes directly to the house battery?   You would then have two separate controllers charging the battery independently.  Should be Ok?  I had also read somewhere on this forum that if a single controller has multiple solar panels connected that they should be identical?
2015 Hawk, Silver Spur Interior, Fiberglass siding.  2008 F250 4x4 Supercab
#8 ckent323
ckent323
  • 1,227 posts
Posted 01 April 2020 - 10:00 PM
I don't think the controller cares where the power comes from.  They are designed to take an input of some amount say 19.6 V and output 13 v or 14 v, as long as you do not exceed the voltage or current input limits of the controller.  However, mixing panels may be less efficient than if they were all the same make and model.
https://solarpanelsv...g-solar-panels/
On the other end however it is best if all the batteries being charged are the same.
Edited by ckent323, 01 April 2020 - 10:02 PM.
#9 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,962 posts
  • LocationCalgary, Alberta
Posted 02 April 2020 - 04:23 AM
yes, that works too.  You will really want to have a battery monitor with a shunt, like the Victron BMV 712, to keep tabs on the battery SOC, especially with two chargers since neither charger will be "aware" of what the other one is doing.
#10 BigRanchInSky
BigRanchInSky
  • PipPipPip
  • 45 posts
  • LocationUtah
Posted 03 April 2020 - 06:12 PM
Wow, such great info, thank you!
RE the size of the Coleman panel: ouch it IS big, and heavy @17 lbs vs the foldable one @6 lbs for the one linked above...so I'm thinking it was a rash purchase and I might need to return it to Costco. Drat. Oh, well, better now than after I get it all unwrapped, etc.
And adding a shunt with Victron 712 sounds like an excellent idea, but I'm going to have to research like mad as to how and where to add that. Looks like the Victron unit come with a shunt according to this video:
Now I'm re-thinking if I can handle this...(I can't). I've actually never run out of power with the supplied 160 watt solar, I was thinking more=better. It may be time to simply ask if it's a good idea to go to all the trouble to add another set of components to the 160w system.
If anything I'm even more impressed every day with the components and build quality of the Hawk: it's really worth every penny, although it would've been nice to have a Victron controller installed, but they can't have every single available option in their builds.
Adding the Victron unit would be great but even that is way above my ultra novice level.
I think I'll shut this down before I waste anyone else's time. I'm glad I waded out into the stream and found it hip deep before I tried to drive through it, alone.
Also tagged with one or more of these keywords: Solar, Coleman, Costco
