Parking light randomly came on.
#1
Posted 06 April 2020 - 04:04 AM
#2
Posted 06 April 2020 - 12:17 PM
#3
Posted 06 April 2020 - 12:42 PM
Are you talking about the running lights on the camper?
No. The camper is not on right now. The light was on the truck. The corrosion was on the bed plug for the camper to truck connection.
#4
Posted 06 April 2020 - 03:41 PM
The fact that it's just one light and not all parking lights, there is a possibility that it is a grounding issue. Check to see if the light is grounded locally(to frame/chassis) or it is in the harness and returns to a main ground buss. Clean grd connection at chassis and/or connectors and inspect wire for nicks or swelling(corrosion) inside the insulation. If you can isolate the ground return in the circuit you could check the wire resistance.
#5
Posted 06 April 2020 - 04:49 PM
If it reoccurs, you might check the wiring where the installer tied the camper clearance lights into the truck wiring.
I am haunted by waters
