OK...as usual I got lost in this thread...You run the 4x4 to lube the gears once a month..why? What difference does it make to move the lube around inside a gear box or transfer case if the vehicle is not being driven? I get that you need lube distributed within the cases and on the gears but why is it "time dependent"? If you let the truck sit for two years what damage is done? If after two years you slowly run the vehicle under light load until the lube is distributed what harm could happen?
Not being a wise guy here, but I just don't see the purpose and what damage would be done.
Thanks for any explanations..Phil
