Electrical Woes
fault
59 replies to this topic
#1 buckland
buckland
  • 3,078 posts
  • LocationNew England
Posted 19 May 2020 - 03:01 PM
Perplexed. 2011 FWC Eagle. 160 W panel on roof, 100 W portable. Battleborn 100AH LiFePo4 battery 12V. Victron 100-20 controller. Blue Seas MM ACR, Isotherm DC fridge, Fantastic fan (with speed mod). Heater. LED Lights and USB plugs. Factory Iota. Renogy 1000 W inverter (new... not yet used)
I believe I have a fault (my wife will agree) somewhere. I had this problem last year on a trip across Labrador and Newfoundland with my homemade LiFePo4 battery (which I blamed for the problem... but now not likely). I bought a new Battleborn battery. When installed same issue.
I am definitely not in  my comfort zone with electrics though I tend to try and a little knowledge can be dangerous. Either there is a fault somewhere or I have done something wrong (my fault).
Everything is the same as when I had 2 AGM batteries when all worked fine except I upgraded to the Victron100-20 when I switched from AGM to Lithium. I had installed a new thermostat for the furnace but that is just 2 wire plug. I installed the Isotherm 65 fridge 3 years ago and it has run perfectly.
I will attach a sketch of how I wired everything in the battery box as well as a screen shot of the Victron APP.  I do not feel the need to attach the truck to camper electrically with the plug as the solar should be enough for my needs but don't mind doing so.
(ACR switch settings?).
What happens:
Pull down the main electric knob to "ON". APP shows Battery at 14 Volts Panel at 20 V 2 Watts. As soon As I turn on fridge or Fantastic fan the APP shows the battery drop to 7 Volts. The CO alarm starts to chirp. Fan slowly dies. Fridge never cools. This is exactly what happened with my DIY battery so I thought it had to be my build but now I see it is something else. (The other "sign" was I plugged in an eBike battery charger 240W... into the inverter and turned on the inverter.... the fault alarm went off... immediately turned off the inverter).
I checked the breakers and clear snapped each, all OK. No fuses are burned out. (BTW... how to know what each is to?) LED lights work. I pulled the Iota out and checked all connections in the back... all seem tight.
How does one chase down a fault? (I have a Fluke meter).
Lordwoodcraft  instagram        Rob
The only people who ever get anyplace interesting are the people who get lost.
Henry David Thoreau
"Work to achieve not to acquire"
#2 Bosque Bill
Bosque Bill
  • 743 posts
  • LocationAlbuquerque, NM
Posted 19 May 2020 - 03:24 PM
You said, "all worked fine except I upgraded to the Victron100-20". Why are you not considering that this is the problem? Bridge the battery(+) to the load(+) and see if the problem persists: if no, then the Victron may be the problem; if yes, then the battery may be the problem.
"I'm not an expert; I'm an enthusiast!" - New Mexico, U.S.A - The Land of Enchantment
http://bosquebill.blogspot.com My Travel Blog
http://www.bosquebill.com My New Mexico Website
2013 Toyota Tacoma Access Cab SR5 V6 4x4 - 2013 FWC Fleet
#3 PaulT
PaulT
    Need gumbo
  • 2,611 posts
  • LocationHillsboro, Oregon
Posted 19 May 2020 - 04:12 PM
Is the ground bus connected to the battery anywhere?
If L is the load out of the Victron, is the ACR there to charge the truck battery?
As drawn, it appears that the truck cannot charge the camper battery as the ACR output does not connect to battery positive.
#4 rando
rando
  • 1,638 posts
  • LocationColorado
Posted 19 May 2020 - 05:02 PM
It looks like everything is wired through the load terminals on your MPPT charge controller?
If that is the case, I am guessing one of your loads (inverter for sure, fridge possibly) has enough in rush (or startup) current to kick the over current protection on the load terminals of the solar controller.   When it shuts down next, take a look at the load status in the Victron App page for the solar controller - I bet you it is off.  You can switch it back on through the Victron App, but it may just trip again once whatever is causing the in rush starts back up again. The easy way to fix this in the short term is to by-pass the load terminals and connect all your loads direct to the battery.
That is a bummer that DIY lithium battery did not work out for you (and maybe it was working fine all along) but I also completely understand getting frustrated and wanting to limit the number of possible causes for a problem.
What happens:
Edited by rando, 19 May 2020 - 05:04 PM.
2016 Fleet Flatbed
2016 Toyota Tacoma
#5 pvstoy
pvstoy
  • 2,768 posts
  • LocationCarson City, NV
Posted 19 May 2020 - 05:03 PM
Also I would be looking at ALL your grounds for loose or shorts.  When you put a load on the system it fails, that shows a loose shorted out connection.  That goes for the positives too.
I agree with the what was said about the ACR as your wiring diagram seems not complete.
Patrick
2015 FWC Hawk Flatbed
#6 pvstoy
pvstoy
  • 2,768 posts
Posted 19 May 2020 - 05:06 PM
Thanks Rando, I forgot about the inrush flow on the load port of the solar controller.  I don't use it so I over look it.
Patrick
#7 rando
rando
  • 1,638 posts
  • LocationColorado
Posted 19 May 2020 - 05:13 PM
I have my system wired through the load terminals as a secondary Low Voltage Disconnect to trip before my lithium BMS trips and to get the net solar charge current.    Very occasionally, when Libra is in ascension, and the fridge happens to cycle right as the water heater lights and all the camper lights are on, it will trip the over current.  I added a bypass switch that will bootstrap the load terminals to overcome the in rush.  Flick the bypass on for 3 seconds and you are back in business.
PS I don't have my inverter wired through the load terminals - it will definitely trip the current limit when it fires up.
Edited by rando, 19 May 2020 - 05:14 PM.
2016 Fleet Flatbed
2016 Toyota Tacoma
#8 DanoT
DanoT
  • 278 posts
  • LocationSun Peaks, B.C.
Posted 19 May 2020 - 05:21 PM
I don't know much about electricity but people who do have recommended coating wire connections and terminals with dielectric grease. Apparently it repels moisture and promotes the flow of electricity.
1991 Dodge CTD, owned since new. 2011 Coyote RV Phoenix pop-up camper, custom made for the Canadian winter.
#9 buckland
buckland
  • 3,078 posts
Posted 19 May 2020 - 06:52 PM
Lets see if I can make sense...
PaulT: Should there be an additional wire from Battery + to ACR  OR (see below Rando)
Bosque Bill: In your test is the "Bridge" wire an additional wire leaving all else attached?
PVSToy: I have checked all connections I can get to also will try PaulT's idea)
Rando: Should I just not use the Victron Controller LOAD and go from the ACR to Battery?
  That is... Have a wire from the negative camper bus bar  go to the "MAIN" on the ACR   AND should the red LOAD wire go to the Battery +  (from ACR) not use the Victron's load connections?
And to all thank you for your patience and advice.
Today is the first warm day and I got the camper (on trailer) out of the barn in hopes of a run to the hills soon.
Rob
Henry David Thoreau
#10 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,950 posts
  • LocationCalgary, Alberta
Posted 19 May 2020 - 07:38 PM
Rob
What I can see:
Your ACR is miss-wired.  The RED wire in your pic should to directly to the +ve terminal on the battery, hopefully with a breaker close to the +ve post on your new BB battery.
Your new BB is pretty much fully charged, hence the low power output of the Victron.
Do you have a Victron BMV too?  If so, where is the shunt in this circuit?
Your Renogy 1000W can draw (1000/12.2 =) 82A under full load.  It should not be connected to the Load outputs of your MPPT.
If as rando suggests your Load Output is OFF in the Victron App, then you should see zero amps/power to your in camper loads... fan, refer, etc.  That you are getting some (if load is off) suggests a cross connect somewhere.
Where does the 2nd wire (white) that is sharing the RED terminal on the ACR going?
