Continued from above....
Drivers side front shock going in.
On the passenger side these two tabs need to be removed, once again the ultrasonic tool made quick work here.
Using snap ties to hold the wiring in place.
Passenger side shock installed.
Trimming the inner fender liners to fit around the strut drop brackets and the upper shock mounts. A air powered saw works awesome for this task. A De-burring tool works really well for cleaning up the edges after the cuts. The instructions also cover further trimming to fit 35" tires, since I'm running 34" tires I decided to skip the further trimming and see how everything plays together before completing these steps.
Test fitting for clearance around the shock....just a bit more needed.
Continued Below....
