Continued From Above....
The controls to the Switch pro are in my headliner, located within easy reach just above the dome light.
With the compressor wired and now fully installed I turned my attention to setting up a dual tire inflation setup. This setup will allow me to fill (Or deflate) two tires at once. Since I run my front tires at a different pressure than the rear I'm going to make a two tire setup so I can fill the fronts as a pair and then the rears as a pair. You could also make a 4 tire setup with the addition of two more splitters. I'm making up two of these units, one for myself and one for my father to carry in his Tacoma.
You can buy these dual & quad inflation setups pre-made but the cost is higher and with the Flexzilla Pro hose I can change the length of hose as needed, if I get a hole in a hose I can shorten the hose in the field with the re-usable ends and keep on using the setup.
This setup costs $135 to make, including all three sections of air hose and the digital gauge.
Note: The links below are my Amazon Affiliate links, I make a small portion each time someone purchases from Amazon using one of my links, at no extra cost to the buyer. I only provide links to items that I personally like and use myself. i use the money to put back into my builds and support making videos/posts. If you prefer not to use my links you can search for the same items directly off Amazon. Thank you for the support!
1/4" Brass ball Valve (Quantity 1) - On Amazon here: CLICK HERE
Lock on Air Chuck (Quantity 2) - On Amazon here: CLICK HERE
Flexzilla Pro Hose (100' is perfect for two setups, 50' for one) - On Amazon Here: CLICK HERE
Digital Pressure Gauge - On Amazon Here: CLICK HERE
Flexzilla Extra Ends (Quantity 4 for 1 assembly) - On Amazon Here: CLICK HERE
Milton 1/4" Male Air Fitting (Quantity 1) - On Amazon Here: CLICK HERE
Milton 1/4" Quick Coupler Air Fitting Male (Quantity 2) - On Amazon Here: CLICK HERE
Milton 1/4" Quick Coupler Air Fitting Female (Quantity 1) - On Amazon Here: CLICK HERE
Milton 1/4" Female Air Fitting (Quantity 3) - On Amazon Here: CLICK HERE
1/4" Brass 4 way manifold (Quantity 1) - On Amazon Here: CLICK HERE
Storage Bag for completed twin filler system - On Amazon Here: CLICK HERE
Laying the parts out to get started, most but not all of the parts are laid out there.
After measuring enough hose to reach just past the rear of the van I cut the hose at that location. I wanted the main hose to be long enough to use by itself at all 4 tires if I choose...I like options!
The ends are aircraft aluminum, you slide the hose through the flexible whip then press the hose onto the barb. When you screw the fittings together it compresses the hose and locks it in place. Simple, fast and works great!
Manifold assembled and shorter hoses made up.
Both units finished.
JT Tire Pro Deflators. I carry a set of these in the van to make quick work of deflating the tires. You set the desired pressure and screw them onto each tire. All 4 tires will air down till they meet the set pressure and then they will seat and stop blowing, unscrew the units and your ready for off road travel! I like these units as they save a lot of time if your deflating all 4 tires over doing each tire individually. I've found the accuracy to be within a couple pounds of set pressure, perfect for deflated tires.
J.T. Pro Automatic Deflators - On Amazon here: CLICK HERE
Continued below....
Edited by Hodakaguy, 11 May 2022 - 02:18 AM.
