Assuming 15' each way from the camper to the alternator with 10AWG wire, you will be dropping around 1V at 30A. What is the alternator output voltage at idle? It should be > 13.4V, in which case the 1V drop would be OK. Maybe there are some bad connections in the path? Or do you still have the 30A circuit breaker in the loop?
I do have a 30amp fuse on that 10awg wire running from the engine battery to the charger.
Alternator voltage at idle is 13.8 -14.2v.
Edited by BurnsMoto, 01 September 2020 - 06:49 PM.
