Vic, I’ve been researching thermally activated fans for the same reason. Can you tell us what your using?
Installing DC-DC Charger in 2015 Fleet FD
#21
Posted 15 January 2021 - 05:50 AM
2018 Ram 3500 Mega Cab 4x4 Diesel, 2015 Hawk Silver Spur Exterior, Front Dinette
#22
Posted 15 January 2021 - 04:19 PM
Can you mount the DC/DC in the engine compartment; assuming the motor fan will provide sufficient air circulation?
And if it is in the battery compartment will that [heat] not create a problem for Li batteries?
FYI...the recommendation I was given was 4g wire for a DC/DC; assuming a significant run of wire.
Edited by Wallowa, 15 January 2021 - 04:19 PM.
#23
Posted 15 January 2021 - 07:12 PM
The thermal sensor I and others have been using is:
https://www.amazon.c...e?ie=UTF8&psc=1
I clipped it to a heat sink fin and it works great. My DC-DC is under the counter and the fan is mounted behind the (enlarged) vent hole. There is no room in the battery compartment in our front dinette Fleet.
10 AWG was not sufficient - it resulted in DC-DC cycling (as others have found). 8 AWG stopped the cycling, 6 AWG would give plenty of margin. 4 AWG is just more expensive and harder to wire and does not buy you anything (unless you plan to upgrade to a 100 A DC-DC and heavy duty alternator).
2015 Fleet on 2019 Ranger
#24
Posted 17 January 2021 - 05:08 AM
What Jack said below.
The fan I use is similar to this one. Mine is 45CFM
