A cautionary tale & question, anyone had issues with the SAE Solar roof outlet?
  • Please log in to reply
7 replies to this topic
#1 Stokeme
Stokeme
  • 373 posts
  • LocationNorCal
Posted 03 July 2020 - 03:27 PM
When I removed my roof panels & frame I had to of course unplug the SAE connector from the SAE roof outlet. The pigtail & the POS metal prong on the plug looked pretty aged, but Ok. I tested the panel’s V in the side yard & then moved to the backyard for my “formal” panel comparison testing. I setup & tested again, it registered on the multimeter, & then all of a sudden, the meter went to zero. I first thought I had to reset the meter tips into the plug, but as I went to do that, I could see the POS prong had broken off the plug. Too old & brittle I guess. It probably would have held up plugged in place on the roof for a while, but at some point, it would have lost contact leaving the system w/o any incoming Current. I had made a new pigtail, with Mc4 connectors, so I had an immediate replacement. I’ll have to make another. I now have a greater concern about the roof outlet. Has anyone had any issues with their Solar SAE roof outlet due to age? A broken roof outlet prong is something I can not easily, or at all, replace. Really problematic.
Edited by Stokeme, 03 July 2020 - 03:55 PM.
#2 Machinebuilder
Machinebuilder
  • 481 posts
  • LocationEast Tennessee
Posted 04 July 2020 - 12:13 PM
I replaced the roof connection with one of these
https://www.amazon.c...0?ie=UTF8&psc=1
It let me eliminate one connection point, and I had bumped the SAE connector with the result being it disconnected. the MC4 connectors are MUCH more secure.
2021 F350 SCLB
FWC Grandby,
EBY Big Country Flatbed, Buckstop Outback front Bumper
Gabby (GSP), Sox (GSP/American Bulldog)
2011 F150 SCLB HDPP
#3 Stokeme
Stokeme
  • 373 posts
  • LocationNorCal
Posted 04 July 2020 - 02:03 PM
I completely agree. Thanks for the link. I have definitely thought about such a roof outlet. Can you offer any tips about how you handled the install, re interior/exterior? Would appreciate any insight, especially, that might prevent collateral damage.
#4 ckent323
ckent323
  • 1,216 posts
  • LocationSolvang, CA
Posted 04 July 2020 - 07:05 PM
I used a Go Power Solar Entry Plate.  It has worked well for 2 years so far.  Installed with 3M 4200 around and under the perimeter edges.
https://www.amazon.c...tomotive&sr=1-2
Edited by ckent323, 04 July 2020 - 07:06 PM.
1993 Dodge Cummins W-250 Club Cab long bed, 2007 FWC Keystone
#5 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,898 posts
  • LocationCalgary, Alberta
Posted 05 July 2020 - 04:56 AM
Remove the old SAE plug.  You will likely find a connection between the plug and the camper hard-wiring just under the roof's sheet metal.  Cut this off at a length that is usable for you to make new connections to.
Buy one of the suggested roof solar entry plates.  I used one like this
https://www.amazon.c...WCN5BWR4C7CWWT4
Like Ckent says above, seal with 3m 4200 or Dicor Lapseal.
#6 Machinebuilder
Machinebuilder
  • 481 posts
Posted 05 July 2020 - 12:09 PM
As I recall, I took the screws out, carefully cut the sealant to get the SAE plug out and there was connections right there.
to install the new one I used Waco Lever Locks for the wires, Rtv and screws to mount it and Eternabond tape over the mounting flange.
I used what I had laying around.
2021 F350 SCLB
FWC Grandby,
2011 F150 SCLB HDPP
#7 Stokeme
Stokeme
  • 373 posts
  • LocationNorCal
Posted 07 July 2020 - 03:43 PM
Appreciate the feedback as I don’t have these supplies in stock. I am definitely going to swap out my roof outlet,
from SAE to MC4.
Edited by Stokeme, 07 July 2020 - 03:45 PM.
#8 craig333
craig333
    Riley's Human
  • 8,000 posts
  • LocationSacramento
Posted 07 July 2020 - 04:08 PM
I don't like SAE or MC4 connectors. No connectors one mine. I figure the likelihood of my needing to remove the panels is slim and it won't be that big a deal to cut the wires and reconnect if I ever do.
