Awesome thanks Lloyd!
New and some questions
#11
Posted 09 August 2020 - 10:22 PM
#12
Posted 11 August 2020 - 07:04 PM
Ok picking this up this weekend.
Widened the fenders on the M101 and fixed my surge brake (now I have brakes) So all of that is good.
I picked up the 4 Reico jacks after i found out the one old ratchet (not cable) forth the jacks is damaged and the PO is using a pipe wrench. For what ever reason I was more worried about height and never noticed by they only go down to 38" high. If the bottom of the camper is about 19" that means I need to account for another 19 or 20" for a dolly.
I am looking at putting this into my Garage and there is no way it will fit on the trailer. Putting it on the dolly will be easier to move i around and I will be able to do all of the restoration. I was just hoping to make it lower. Maybe I will see if I can use a combination of the two jacks.
Should be a fun Saturday! I will post pictures once I have it in home.
#13
Posted 12 August 2020 - 02:58 AM
“I was looking at those Olympian Wave 3 heaters, so thank you for that. Does it fit in the original location or did you have to modify anything. Or is it loose.”
I used 1/4” plywood to fill the hole left from removal of the stock heater, and hung the Wave3 on it. I leave the front window above the bed open a bit to insure a source of oxygen, but I do that even when the heater isn’t on.
#14
Posted 12 August 2020 - 02:52 PM
Thanks Keith.
#15
Posted 12 August 2020 - 02:54 PM
New question. the slide out sleep cot. Does anyone know the max weight?
I am wondering if my 10 year old can sleep on it. I may have to replace it if it is warn but still a question.
