What altitude were you at?
I was at 6-7,000 in Idaho, but works working no better at home near sea level. Hoping Stan’s offer of help will help figure something out!
Posted 23 August 2020 - 10:05 PM
Posted 23 August 2020 - 10:53 PM
Posted 23 August 2020 - 11:54 PM
I found a video searching for “four wheel” and “sail switch” and it’s now fixed. Thanks for the help, all!
Well done!
I am haunted by waters
Posted 09 September 2020 - 05:23 PM
Here is a link to replacing Sail Switch video:
and this one:
I'm currently troubleshooting my 1 year old furnace.
______________________________
2019 Hawk / Ford F250
Posted 10 September 2020 - 03:12 PM
The saga continues...
Backstory: [Me: 2019 Hawk-super clean] I was trying to get the furnace to light at 8,000 ft and 9,500 ft elevation. It would spin up for about 15 seconds and then shut off. Plenty of battery juice. Drat!
Back home I took unit outside cover off and checked sail switch with for debris/dust/gunk, it was pristine, put back in carefully.* Back home at 5,300 ft in my driveway the furnace works perfectly, starts right up, zero issues.
*Obviously you gotta check to see if your entire unit is fouled with debris/dust/gunk—and don't forget the thermostat, which can get multitudes of spider eggs, food and whatnot into it. Or bad battery (mine doesn't have one).
Update. I spoke to Stan and one of the techs at FWC. They are telling me that Dometic (all most all other) propane furnaces cannot function above a certain altitude. Huh?
"So, the high elevation limitation is that the air is thinner and the fan only runs at one speed. That fan has to push the sail of the sail switch over to activate the firing order of the furnace. If the air volume isn’t capable of doing that, the furnace definitely will not light. This also tells the furnace that the air/fuel ratio is too low(low air/high fuel). If lit, it would cause a rich mixture possibly causing a weak flame and/or high CO levels. These are safety devices that prevent accidents. This is not limited to Atwood/Dometic products. These are safety devices found in every furnace that is legally sold/installed as OEM equipment in the United States.
[response to me telling him I cycled power a bunch times using the thermostat trying to get it to start] Also, by turning the unit off and then back on again in succession, could trigger the safety lockout feature(breaker) that’s located behind the outside furnace door.
There are workarounds to furnaces that do work at higher elevations but, Four Wheel Campers cannot install them due to restrictions and liability limitations. Espar Diesel heaters are phenomenal and work very well in almost all elevations but, they can only be added as an aftermarket item by a distributor/installer. I believe Rocky Mountain FWC installs them in some camper models. Propex/Heatsource HS2000 is a great propane model that works good too, and is very popular in Europe but again, is not certified for OEM manufacturers to install here in the US. I can personally understand the frustration, as I too have been in the same situation with that brand of furnace in many different makes of campers and travel trailers besides FWC products."
Fair enough, I understand the science/safety and legal limitations. I was ignorant about the entire high-altitude issue. Color me city boi again!
And the last couple of days I've read about a zillion blogs and forums about the subject. I'd LOVE to get a Propex/Heatsource HS2000 installed, but finding a certified shop to do it is going to be tough. (Anyone got any leads? I'm in Utah but I can road trip to get it done. Road Trips are fun! )
From my reading, I've found a few ideas I'll pass along (one untested and possibly very dangerous):
Please, anyone wanting to add to or correct any of this malarky post it or PM me and I'll fix my info.
Sorry for the epic post, too much coffee!
Edited by BigRanchInSky, 10 September 2020 - 03:16 PM.
Posted 10 September 2020 - 03:20 PM
What's the max altitude the furnace is designed for? I was at about 6200 feet a couple days ago and it worked fine.
Posted 10 September 2020 - 04:07 PM
My Granby and I live in Fairplay, CO at 10,082 feet.
I went through the same pains but I got it figured out.
There are adjustments to be made that will get it to work reliably up here.
There is also a "high altitude kit" that is sold with mixed reviews but the design idea is clear when you see the unit.
Posted 10 September 2020 - 05:03 PM
BigRanchInSky,
Search for “propex fife”
There is a dealer in Fife, Washington near Tacoma that mostly specializes in Vanagons. They are the Propex dealer for the PNW. Give them a call to see if they can help.
Posted 11 September 2020 - 05:18 PM
BigRanchInSky,
Thank you!
Posted 11 September 2020 - 05:22 PM
What are these "adjustments" you speak of? Did you do them or did your RV shop have the methodology? Did if require new or retooling parts or just adjustments to the regulator(s), tanks and/or the furnace itself?
Sorry if this rekindling old info...
