If you have added a 2x4 or other similar dimension wooden frame/supports to raise the camper because your truck bed sidewall is much taller than back in the day, this may work for you.....
As you know, the floor and sidewalls and front/rear walls are not really very well designed for 50-60 years of use and the wood can and will become LESS sturdy over time. The rear steel section that goes across the rear panel and secures it to the floor is notched where the door is and this weak spot is where cracks develop. After that, the sides of the rear panel splay out at the top and you can see how the rear door no longer is aligned from top to bottom.
I have used the shims, but after a while, they become flattened out or are squished out from the movement of camper to truck bed.
So...if you have a 2 x 4 or higher framework to support the camper above the truck sidewalls (it should NEVER rest on the side walls of the truck bed!!!!!!!!!!!!, got that?), you can purchase some 1/4" by 2" angle iron and rout that rear wooden crossmember and sink that angle iron into it top and rear....then the rear panel/floor assembly will sit on some STEEL for support...if you still see some flex and the door needs a bit more closing, use shims attached to the bottom of the wooden frame.
